Thread: Odd ‘motor’ sound when ignition off
  1. Odd ‘motor’ sound when ignition off
    Nov 2008
    Hi - I’m after any advice on a sound my Passat makes. I’d describe the sound like a stepper motor but more or less constantly running, with a brief pause before starting again.
    The noise comes from the drivers side wheel arch area, but I’d guess from within engine bay. Loud enough to hear from inside the cabin.
    It does not sound if the car has been sitting locked. However, once unlocked, the noise starts and doesn’t seem to stop all the while the car is unlocked. It’s not loud enough to hear if this continues once the engine is running.
    It could be normal - but doesn’t sound as though it should be...
    The car’a B8 1.6 BMT 2015
    Any advice would be appreciated!
    Phil
  2. Re: Odd ‘motor’ sound when ignition off
    Mar 2021
    Ripon
    7 Post(s)
    Mine does exactly the same. Hadn't really thought about it. Nothings gone wrong and like you say once engine is turned on you don't notice it.
  3. Re: Odd ‘motor’ sound when ignition off
    Nov 2008
    Thanks - could be normal… I’ve had the car for 4 years, yet only noticed it during the past few months. As you say - nothing appears wrong so maybe nothing to worry about.
  4. Re: Odd ‘motor’ sound when ignition off
    1841 Post(s)
    That is often the warning sound for impending EGR unit failure, extremely common on the CAYC engine.
  5. Re: Odd ‘motor’ sound when ignition off
    Mar 2021
    Ripon
    7 Post(s)
    My engine code is CRLB for what is worth!
  1. Strange sound from under the bonnet when ignition is on
    By Alex5555 in forum Golf MK6 - 2009 - 2013
    Last Post: 21-10-2015, 10:29 PM
  2. vibrating motor sound?
    By fourringsrus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-10-2010, 08:52 PM
  3. Question Beeping sound when ignition is switched off
    By IngAudi in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-10-2009, 09:54 PM
  4. Audi A6 TDI -Strange sound on turning ignition
    By teejay804 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 04-04-2008, 09:34 AM
  5. Ignition switch/barrel and starter motor
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2008, 08:25 AM
