Thread: Audi A4 B7 2.0 TDI BPW P2002 Code
  1. Audi A4 B7 2.0 TDI BPW P2002 Code
    Jul 2021
    State
    I manage to get some scans on my audi, problem is that: Glow plug(intermitent light) and dpf symbol on dash. Cars runs fine, can be rev up to 5k with no problem, but dpf does not regenerate anymore, the g450 was replace with one OE, but same readings. Dpf was cleaner with hot air, also with chemicals, very clean was. Also egr valve opening is always 100%. this opening shouldn't be 100% just when I press accelerator pedal ? This can cause the dpf not to regenerate? Also soot is around 66% and goes up. Already 4 regen failed. Also pre-dpf temperatura rarely gets over 350 *celsius. No other dtcs, just p2002.
    This car has egr cooler ? Could be this my problem ? How to test it ?
  2. Re: Audi A4 B7 2.0 TDI BPW P2002 Code
    May 2012
    Everywhere
    308 Post(s)
  3. Re: Audi A4 B7 2.0 TDI BPW P2002 Code
    Jul 2021
    State
    What do you mean?
  4. Re: Audi A4 B7 2.0 TDI BPW P2002 Code
    May 2012
    Everywhere
    308 Post(s)
    The planned obsolescence that Audi built into the car to self destruct .
    As Audi Driver magazine found out 12 years ago .
  1. DPF issues - soot level 6.63 error p2002 p2463 05188 05189
    By Heathy in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-12-2020, 09:52 PM
  2. P2002, p0544 error codes
    By aj1soad in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 05-05-2019, 11:51 AM
  3. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  4. Please Help Error code first one P2002
    By teddy2k5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2014, 12:12 PM
  5. Audi TT Chorus stereo code not with car, help needed getting code
    By acordery in forum TT - 8N Forum - 1998 - 2006
    Last Post: 09-08-2013, 02:38 AM
