Thread: Mk 4 Golf SDI 1.9 coolant temperature sensor change.
  1. Mk 4 Golf SDI 1.9 coolant temperature sensor change.
    Apr 2007
    So the temperature gauge on the dash isn't registering at all but before that it was working intermittently. Seems like i need to change the coolant sensor. The proper way i suppose is to drain the system but that involves removing the under engine protector which i've not long done to change the oil. Some tutorials show to unclip the sensor without draining the system and quickly put the new sensor in. I can't get the wired connector off because the tab is between the sensor and the engine block. If i pull out the sensor and let the coolant out how much am i likely to lose? I'm thinking about putting some kind of plastic tray under the sensor to catch it but obviously the size of it depends on what's lost. Thanks in advance.
  2. Re: Mk 4 Golf SDI 1.9 coolant temperature sensor change.
    Southampton, UK.
    I changed mine many years ago and did not drain the coolant. Remove the sensor (be prepared for some coolant loss) and top up afterwards. Obviously, keep checking the level and release trapped air from expansion bottle afterwards.
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: Mk 4 Golf SDI 1.9 coolant temperature sensor change.
    Apr 2007
    Thanks, i've found a drain tap at the bottom of the radiator so i'm going to drain the system and change the thermostat, housing and temperature sensor all at once.
    Quote Originally Posted by herby0001 View Post
  1. MK3 Golf 1.4 ABD Coolant Temperature Sensor (CTS)
    By spud72UK in forum Golf MK3 - 1993 - 1999
    Last Post: 12-04-2016, 02:00 PM
  2. Which Coolant Temperature Sensor? for 1999 Mk 4 Golf GT Tdi
    By Grandad Dave in forum Golf MK4 - 1999 - 2004
    Last Post: 17-02-2012, 05:03 PM
  3. how to change polo 2002 Coolant temperature sensor
    By VinceVegaUK in forum Polo - Derby - Lupo - Fox
    Last Post: 31-08-2009, 08:39 PM
  4. Question Coolant temperature sensor
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 02-01-2009, 11:18 PM
  5. Coolant Temperature Sensor - CHANGE IT !
    By frost015 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-10-2008, 12:26 AM
