Thread: coolant sensors/fans/thermostat
  1. coolant sensors/fans/thermostat
    May 2020
    Pontyclun
    i have a mk5 golf 1.9tdi bxe engine.
    The temp gauge in the car maxes out at the 75⁰ mark. The cooling fans never come on to cool.
    The car gets warm quick and never overcools, maintains constant hot at the heater fan.
    I replaced the 2 coolant sensors & thermostat a while ago. all were genuine vag parts from tps.
    What can i check to find out the cause of the issue?
    When i drove the car yesterday on the motorway for 30 miles it didn't overheat or overcool.
    I took a temp reading in a few places and below are just a couple of those. The car has no error codes.
    coolant pipe by thermostat 73⁰
    coolant pipe by fuel pump 76⁰
    top of radiator 71⁰
    top of engine block above thermostat was 93⁰
  2. Re: coolant sensors/fans/thermostat
    Aug 2021
    Newport
    If you identify the sensor responsible for the gauge what does the temp reading say there?
    sounds as if it’s reading right looking at some of those temps.
    cant really explain why it would be running cooler though if the stat was a genuine item.
  3. Re: coolant sensors/fans/thermostat
    1840 Post(s)
    The gauge should read 90 by a real 77 and still read 90 at 116 so to me the gauge is faulty, this can be checked using VCDS or similar in output test where the gauges (all of them) should go full scale deflection, minimum reading and the half way and stay there.
  4. Re: coolant sensors/fans/thermostat
    Mar 2010
    Derry ireland
    60 Post(s)
    The cooling fan (fans) has to be controlled so that allows the engine to maintain a constant temperature and is solely controlled by the ecu .Which gets input from the engine coolant temperature sensor I would start by checking out wiring from coolant temp sensor load testing to ecu pin out nos
  5. Re: coolant sensors/fans/thermostat
    May 2020
    Pontyclun
    I assume by engine temp sensor you're referring the one above the gearbox? rather than generic terminology.
    Do you know what number pins at the ecu that sensor corresponds to?
    I cannot read electric diagrams but can follow/understand wiring instructions
  1. Question Touran Help !!! Coolant & Fans
    By caribsimon in forum Touran - Sharan - Caravelle
    Last Post: 23-01-2017, 07:02 PM
  2. coolant fans start up from cold???
    By PhilG8679 in forum 1.8T - Engine
    Last Post: 18-05-2010, 03:58 PM
  3. Question Coolant Fans not working a3 1.6 2001
    By jiml2510 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-08-2009, 01:27 PM
  4. Radiator Fans possible Thermostat Issue
    By soco in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2008, 05:53 AM
  5. X Plate 1.8T - Fans stay on, thermostat dodgy
    By shayd in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2008, 11:45 PM
