Thread: Air Con Leak - Low Pressure Side
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 57
  1. Air Con Leak - Low Pressure Side
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Got an air con leak on low pressure side..... doesn’t hold vacuum.
    any ideas? Going to replace seals first.
    condenser was replaced last year with ECP EIS Part (222440611) from memory.
  2. Re: Air Con Leak - Low Pressure Side
    Jul 2018
    8 Post(s)
    Replaced the following seals and performing another vacuum test.
    4E0 260 749 A
    3D0 260 749 C
    8E0 260 749 C
    The 8E0 I removed was damaged so hopefully that was the problem. A small piece was missing from the seal.
  3. Re: Air Con Leak - Low Pressure Side
    1840 Post(s)
    We have trouble with a Golf 5 GTI last week, in the end we found debris from the compressor in the expansion valve, you can store meat in there now it is so cold.
  4. Re: Air Con Leak - Low Pressure Side
    Jul 2018
    8 Post(s)
    It’s passed the vacuum test and been injected with r134a. It gets cold but not down to 8 degrees centigrade when we use a probe in the dash vents. It’s probably about 11/12 it goes down a bit up one acceleration but doesn’t reach 8.
    weak pump?
    where is the expansion valve on the Mk5 BAG engine?
    If you have any pictures or diagrams that would be great.
    thanks
  5. Re: Air Con Leak - Low Pressure Side
    Jul 2018
    8 Post(s)
    Air con is working.
    but still got fault codes on ODIS.
    the ECON light / button doesn’t come on when I press it. It’s constantly out the LED. But does appear to turn compressor ON and OFF as the air does go cold and then hot when pressed again.
    A/C Compressor Regulator Valve N280
    0008- Climate Control Module
    898 10 A/C Compressor activation (open circuit / short circuit to B+ Intermittent)
    Refrigerant Pressure
    229 2 Refrigerant Pressure (lower limit not reached - intermittent)
  6. Re: Air Con Leak - Low Pressure Side
    1840 Post(s)
    If it has a Sanden compressor they are very problematic, we insist on Denso new, not recon. The expansion valve is the coupling on the bulkhead to the evaporator. Genuine they are insane money (hundreds) but Febi list them in the tens but have no stock! ECP have Hella for a good price.
  7. Re: Air Con Leak - Low Pressure Side
    Jul 2018
    8 Post(s)
    Been using the AC for a while now but it’s performance seems to have gone down. Doesn’t appear to be as cold. Must be a refrigerant leak? VCDS is showing 6bar as the refrigerant pressure. Could it be a bad compressor (even though it’s brand new Genuine OEM Denso part?). Or maybe something wrong with the blend flap? Need to check for leaks again and inject with dye and get a UV lamp out again. Hopefully it’s not the condenser or evaporator.
  8. Re: Air Con Leak - Low Pressure Side
    1840 Post(s)
    It needs to be checked on a proper AC system test machine now. I have never had a new Denso fail but it is always possible.
  9. Re: Air Con Leak - Low Pressure Side
    Jul 2018
    8 Post(s)
    Ok no worries I’ll get it hooked up and see what the Low and High pressures are like. We had no issues vacuuming the system and it holding vacuum. It passed that test otherwise it won’t proceed to injecting gas into system. Perhaps there is an issue when it’s pressurised? Leak somewhere? But seeing as there is still pressure / refrigerant must be ok?
    Can the expansion valve have an impact on the cooling performance?
    Condenser was replaced as it was the original one and had taken a beating….so may not be that.
  10. Re: Air Con Leak - Low Pressure Side
    1840 Post(s)
    I had the expansion valve on one cause me grief the end of last year, I hardly ever have to replace them. Genuine were daft money but by Febi incredibly cheap.
  1. Oil leak from driver side
    By Abuabida in forum Bora - 1998 - 2005
    Last Post: 07-04-2017, 08:51 PM
  2. Please Help Oil Leak From Side Of Engine
    By MAF72 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2013, 04:50 PM
  3. Please Help a4 b5 1.6 bad leak at oil pressure switch?
    By tonos in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-02-2010, 07:35 PM
  4. Off-side front oil leak
    By TEEMMERT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 07:50 PM
  5. water leak drivers side on 01 S3 help please
    By scrossley in forum Audi A3 - Archive Topics
    Last Post: 12-12-2008, 03:25 PM
