Thread: Air Con Leak - Low Pressure Side
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
  1. Re: Air Con Leak - Low Pressure Side
    #21
    1841 Post(s)
    I love Wurth products, I have the catalogue beside my bed and read it cover to cover...
  2. Re: Air Con Leak - Low Pressure Side
    #22
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Couldn’t find anything with the leak detection dye which was a bit of a pain! Might need a brighter UV light to help find the leak I think. Still only getting 10 degrees centigrade....think the compressor must not be running correctly or is worn out.....
    any suggestions on what to do next?
    i even got the glovebox out and removed pollen filter to check the evaporator.....couldn’t see any leaks when shining a torch up there and using an inspection mirror....
    im at a bit a loss as to why the gas is leaking out (normally happens over a day or two, so has to be a fairly slowish leak, just can’t detect it).
  3. Re: Air Con Leak - Low Pressure Side
    #23
    1841 Post(s)
    Those compressors are very unreliable, often made by Sanden and we fit brand new Denso units.
  4. Re: Air Con Leak - Low Pressure Side
    #24
    Jul 2018
    8 Post(s)
    Replaced the compressor (Denso 1K0 820 859 T) the other day and regassed - appears to be working great now! Holding pressure. The old compressor looked damp so there must of been a leak within the unit somewhere.
    Getting around 9 degrees Celsius at the side air vent with a temperature probe.
    Was hoping it would be a little cooler.
    What do everyone else get out there? Is this value in the right ball park or should it be cooler?
  5. Re: Air Con Leak - Low Pressure Side
    #25
    1841 Post(s)
    Give it time to run in which really you should do using VCDS.
  6. Re: Air Con Leak - Low Pressure Side
    #26
    Jul 2018
    8 Post(s)
    What can I do on VCDS to help me? Output tests?
  7. Re: Air Con Leak - Low Pressure Side
    #27
    1841 Post(s)
    There is a run in setting in basic settings but it will do it on its own over time.
  8. Re: Air Con Leak - Low Pressure Side
    #28
    Jul 2018
    8 Post(s)
    Can see the high pressure schrader valve appears to bubble when the ac is in use.... so guessing there is a leak there but I
    did replace the valve with a new genuine OEM part so can only guess that I’ve got a bad replacement valve or the whole ac
    pipe needs to be replaced.
    Any ideas why this is happening?
    I made sure the valve is properly seated but still appears to bubble / leak.
    Appreciate any help or advice?
    thanks
  9. Re: Air Con Leak - Low Pressure Side
    #29
    Jul 2018
    8 Post(s)
    Been using the AC for a while now but it’s performance seems to have gone down. Doesn’t appear to be as cold. Must be a refrigerant leak? VCDS is showing 6bar as the refrigerant pressure. Could it be a bad compressor (even though it’s brand new Genuine OEM Denso part?). Or maybe something wrong with the blend flap? Need to check for leaks again and inject with dye and get a UV lamp out again. Hopefully it’s not the condenser or evaporator.
  10. Re: Air Con Leak - Low Pressure Side
    #30
    1841 Post(s)
    It needs to be checked on a proper AC system test machine now. I have never had a new Denso fail but it is always possible.
  1. Oil leak from driver side
    By Abuabida in forum Bora - 1998 - 2005
    Last Post: 07-04-2017, 08:51 PM
  2. Please Help Oil Leak From Side Of Engine
    By MAF72 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2013, 04:50 PM
  3. Please Help a4 b5 1.6 bad leak at oil pressure switch?
    By tonos in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-02-2010, 07:35 PM
  4. Off-side front oil leak
    By TEEMMERT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 07:50 PM
  5. water leak drivers side on 01 S3 help please
    By scrossley in forum Audi A3 - Archive Topics
    Last Post: 12-12-2008, 03:25 PM
