Thread: Air Con Leak - Low Pressure Side
Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
  1. Re: Air Con Leak - Low Pressure Side
    #51
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Had a look at the condenser through the front bumper….looks like it’s taken a few hits from stones / debris. I can clearly see the horizontals have been dinged in 2 areas (enough possibly to cause a leak) but cannot see any signs of oil / refrigerant. Would of thought if it was leaking from there I would see signs of this. Suspecting a hole in the condenser due to damage. However I thought this may have been picked up when performing the vac test prior to injecting the refrigerant. It holds vacuum without an issue.
  2. Re: Air Con Leak - Low Pressure Side
    #52
    131 Post(s)
    1979 Post(s)
    I have had a couple go but as Denso now stipulate you must fit a new one, this gets dealt with during the inevitable compressor change. You should see the way MQB ones rot and fall to bits.
  3. Re: Air Con Leak - Low Pressure Side
    #53
    Jul 2018
    8 Post(s)
    Not heard of MQB. Who are they? A manufacturer / supplier?
    Do you think the damaged captured in the above images enough to cause a leak in the AC system?
  4. Re: Air Con Leak - Low Pressure Side
    #54
    131 Post(s)
    1979 Post(s)
    MQB is Modularer QuerBaukasten (Modular Transverse Matrix) which is the Golf 7 etc platform, Golf 5 is PQ35 (Passagier Quer or Passenger Transverse design 35), funnily enough about ten minutes after I typed that a Golf 7 pulled in with the condenser hanging in pieces. The condenser is not a common PQ35 platform issue, usually it is the pipe on the right inner wing.
  5. Re: Air Con Leak - Low Pressure Side
    #55
    Jul 2018
    8 Post(s)
    Ok thanks Crasher. So which pipe would that be? There are 2 AC lines running down that side. Do they wear through or fail in a particular place?
  6. Re: Air Con Leak - Low Pressure Side
    #56
    131 Post(s)
    1979 Post(s)
    Either of them can corrode through the ally where they touch anything, I forgot though, the pressure switch is extremely prone to leaking.
  7. Re: Air Con Leak - Low Pressure Side
    #57
    Jul 2018
    8 Post(s)
    I’ll have to get the system vacuumed and remove the pipes to confirm the condition of them.
    The pressure switch got replaced with genuine OEM part so hopefully it isn’t leaking. The oring was also replaced with new OEM part.
  1. Oil leak from driver side
    By Abuabida in forum Bora - 1998 - 2005
    Last Post: 07-04-2017, 08:51 PM
  2. Please Help Oil Leak From Side Of Engine
    By MAF72 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2013, 04:50 PM
  3. Please Help a4 b5 1.6 bad leak at oil pressure switch?
    By tonos in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-02-2010, 07:35 PM
  4. Off-side front oil leak
    By TEEMMERT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 07:50 PM
  5. water leak drivers side on 01 S3 help please
    By scrossley in forum Audi A3 - Archive Topics
    Last Post: 12-12-2008, 03:25 PM
