Thread: Golf 1.9 TDI (BXE) Big end bearings replacement & oil pump removal.
  1. Golf 1.9 TDI (BXE) Big end bearings replacement & oil pump removal.
    May 2021
    Norfolk
    Golf 1.9 TDI (BXE) big end bearings replacement & oil pump removal, morning people I’ve got a job on next week on a golf (BXE) obviously understand that usually timing need to be at TDC before removing the oil pump on other VAG’S 2.0 TFSI engine's, take it that oil pump can be removed without removing front main oil seal cover right? I’ve listed the parts below is there anything else which I’ll need thanks
    new parts bought from TPS
    rod bolts
    big end bearings
    oil sprocket bolt
    oil pickup o’ring
    sealant
  2. Re: Golf 1.9 TDI (BXE) Big end bearings replacement & oil pump removal.
    108 Post(s)
    1816 Post(s)
    No, it’s very straightforward. Post a pic of the shells when done to show if the uppers are hammered as usual.
  3. Re: Golf 1.9 TDI (BXE) Big end bearings replacement & oil pump removal.
    May 2021
    Norfolk
    Thanks for your reply Crasher will post some pics when it’s done.
  4. Re: Golf 1.9 TDI (BXE) Big end bearings replacement & oil pump removal.
    May 2017
    Cardiff
    12 Post(s)
    How many miles on the car, what sort of life has it had and what service routines were performed please?
  1. Water Pump Replacement on Golf mk5 tsi 170 1.4tsi
    By Andy_D in forum Golf MK5 - 2004 - 2009
    Last Post: 13-02-2015, 03:17 PM
  2. Please Help Golf II GTi 8v 1990 Water Pump Removal
    By deanwhiting920 in forum Golf MK2 - 1984 - 1992
    Last Post: 05-11-2009, 09:49 PM
  3. Question Steering Pump Removal from MK3 Golf TD engine code 'aaz'
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-04-2009, 11:37 AM
  4. Golf Mk3 Fuel pump removal
    By rogernote in forum Golf MK3 - 1993 - 1999
    Last Post: 04-09-2008, 08:16 PM
  5. Front wheel bearings REMOVAL Polo 98 1.0
    By Hiral in forum Polo - Derby - Lupo - Fox
    Last Post: 16-11-2007, 01:28 PM
