Thread: B5 2.5tdi v6 problems!!!
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: B5 2.5tdi v6 problems!!!
    #11
    1840 Post(s)
    If it won't go with a sniff, you have a compression problem and as it has a proper lift pump, it should not need any help getting fuel to the VEP. 0550 what? Control difference, regulating limit low/high or implausible signal?
  2. Re: B5 2.5tdi v6 problems!!!
    #12
    Jan 2021
    GB worcester
    It will go with a sniff but won’t stay running, and 0550 control difference intermittent
  3. Re: B5 2.5tdi v6 problems!!!
    #13
    1840 Post(s)
    Out of the old book of words
  4. Re: B5 2.5tdi v6 problems!!!
    #14
    Jan 2021
    GB worcester
    I have the lines running into a drum to eliminate the tank/filter and still nothing, no air in the clear line from what I can see and how would I check the timing range when car isn’t running?
  5. B5 2.5tdi v6 problems!!!
    #15
    Jan 2021
    GB worcester
    Also is there any way of finding out the routing of hard lines from pump to injectors so I can confirm it’s correct
    Scratch that they’re correcta
  6. Re: B5 2.5tdi v6 problems!!!
    #16
    Jan 2021
    GB worcester
    Quick update
    Speedometer doesn’t show any rpm while cranking so I started to think the crankshaft sensor is faulty but I can see rpm with vcds so I’m not sure
    I have fuel at all 6 injectors and it’s a strong spray
  7. Re: B5 2.5tdi v6 problems!!!
    #17
    1840 Post(s)
    When it cranks, does it sound normal with a pulse pulse pulse sensation or just a fast whirring?
  8. Re: B5 2.5tdi v6 problems!!!
    #18
    Jan 2021
    GB worcester
    Sounds normal with a pulse, pitch changes slightly if you hold the throttle and you can smell exhaust so it’s trying
  1. Please Help 2.5tdi v6 AKE -01 camshaft problems
    By GrimNorell in forum Home Tech Shed
    Last Post: 25-05-2022, 10:16 AM
  2. LT 35 2.5TDI Problems
    By Dion lt35 in forum The Commercial Range
    Last Post: 30-06-2018, 07:43 PM
  3. A6 2.5TDI AEL problems
    By turbojunkie in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 29-01-2011, 01:23 PM
  4. 2.5TDI Starting Problems
    By DDe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-06-2008, 01:51 PM
  5. Starting problems 2.5TDI
    By tomnch in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-04-2008, 03:22 PM
