Thread: B5 2.5tdi v6 problems!!!
Results 1 to 10 of 18
  1. B5 2.5tdi v6 problems!!!
    Jan 2021
    GB worcester
    So I picked up a cheap b5 with a 2.5tdi, AFB engine with an AKE ecu, car ran great until I drove uphill with low fuel which killed the really sensitive vp44 pump, fast forward to this week it’s had a new pump fitted, system primed etc and the car still won’t run, it’s the D code pump so not coded in, anyone have any ideas? If I hold it on the starter it puffs a tiny bit of smoke and you can smell that it’s at least trying to burn the fuel.
    Plenty of fuel/pressure at the injectors and no codes whatsoever with vcds
    Any clues before I burn it to the ground and buy a Vauxhall???
  2. Re: B5 2.5tdi v6 problems!!!
    1837 Post(s)
    Which year and 4 wheel drive?
  3. Re: B5 2.5tdi v6 problems!!!
    Jan 2021
    GB worcester
    1999 and front wheel drive
  4. Re: B5 2.5tdi v6 problems!!!
    1837 Post(s)
    Have you checked the swirl pot pump is working?
  5. Re: B5 2.5tdi v6 problems!!!
    Jan 2021
    GB worcester
    Jumping fuse 28 it works fine
  6. Re: B5 2.5tdi v6 problems!!!
    1837 Post(s)
    So it supplies the fuel filter when jumped but is the relay operating it? These get wet and pack up, common issue.
  7. Re: B5 2.5tdi v6 problems!!!
    Jan 2021
    GB worcester
    Not sure, it’s not running dry though it just doesn’t want to fire
  8. Re: B5 2.5tdi v6 problems!!!
    1837 Post(s)
    Have you tried a TINY sniff of brake cleaner?
  9. Re: B5 2.5tdi v6 problems!!!
    Jan 2021
    GB worcester
    Still won’t go
  10. Re: B5 2.5tdi v6 problems!!!
    Jan 2021
    GB worcester
    Update
    00550 fault code stored but no eml, timing checked and engine is at tdc with a pin locked into the pump, got the rear of the car raised to at least level it out to assist not having to pull fuel uphill but still no start
  1. Please Help 2.5tdi v6 AKE -01 camshaft problems
    By GrimNorell in forum Home Tech Shed
    Last Post: 25-05-2022, 10:16 AM
  2. LT 35 2.5TDI Problems
    By Dion lt35 in forum The Commercial Range
    Last Post: 30-06-2018, 07:43 PM
  3. A6 2.5TDI AEL problems
    By turbojunkie in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 29-01-2011, 01:23 PM
  4. 2.5TDI Starting Problems
    By DDe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-06-2008, 01:51 PM
  5. Starting problems 2.5TDI
    By tomnch in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-04-2008, 03:22 PM
