Hi all
I have just had a recon gearbox fitted to my 1.4 mk 4 golf 5 speed some of you may know this.
My dilemer is that the reversing lights are know not working when put into gear. have been told fom the gear box people that the Recon gear box is a later model than the one that bust so requires a different switch does this ring true to anyone.
The garage that put on the box that i give them said it looked like there was a piece missing from within the gearbox which you can see through the hole where the switch locates the bit is shown on the bust on as a small piece of metal 8 mm square ish which moves in and out when moved in to gear which pushes on to the switch making connection thus bring on lights)
Sorry for all the writing hope the extra info helps
