Thread: rear left abs sensor
  1. Question rear left abs sensor
    Jan 2009
    Birmingham
    35 Post(s)
    Just had my abs light and traction light come on.
    Vcds scan shows fault code as 00290 abs wheel speed sesnor rear left (g46) 30-00 open or short to plus
    check measuring blocked and it stay on 1 even when moving.
    ive looked at the part number and its 8E0 927 807 B what does the letter at the end mean is it suppose to be B or G
    car is a audi a4 1.9tdi 54 plate engine code BKE
    thnaks
    will this part be ok
    https://www.ebay.co.uk/itm/174505257...EAAOSwG5xfosTP
  2. Re: rear left abs sensor
    Jan 2009
    Birmingham
    35 Post(s)
    Anyone
  3. Re: rear left abs sensor
    1840 Post(s)
    >2004my (VIN date 4) it was B then for 2005my G so almost pre facelift B, post facelift G.
  4. Re: rear left abs sensor
    Jan 2009
    Birmingham
    35 Post(s)
    Mine is pre facelift so the one in the link won’t be compatible. Will have to get the B one.
    whats the difference in the actual parts b and g ??
  5. Re: rear left abs sensor
    Jan 2009
    Birmingham
    35 Post(s)
    When I check online for the G version it says it’s compatible with my car and when I check the B version it’s says it not so a bit confused know
  6. Re: rear left abs sensor
    Dec 2014
    10 Post(s)
    For my 53 plate it was 8E0927807B
    Full gory details at Rear wheel speed sensor issues
    The Bosch part number for the part I got was 0 265 006 681
    Cheers Ian
  7. Re: rear left abs sensor
    Jan 2009
    Birmingham
    35 Post(s)
    Finally got the abs sensor changed.
    Also changed the rear wheel bearing as well it was making a slight noise and i though might as well because it would give better access to the sensor and i knew the bolt would be seized.
    The bolt was seized solid had to drill and tap it out but in the end all good.
    bearing part no:8E0598611C
    bolt part no:N014704
    Bosch abs sensor part no:0265006681
    The abs sensor that i took off had the part number 8E0927807G i thought it would be B as mine is pre face lift anyway the bosch sensor works fine.
    DRILLED OUT
    TAPPED OUT M6 TAP
    NEW SENSOR FITTED
  1. Rear Left Abs Sensor
    By warptechno in forum Passat CC
    Last Post: 17-05-2019, 10:27 PM
  2. ABS fault - rear left wheel sensor
    By leighmagill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2015, 03:24 PM
  3. ABS problem Ibiza 2007. Rear left sensor
    By awes in forum Ibiza - Cordoba
    Last Post: 25-08-2014, 05:06 PM
  4. front left speed sensor
    By tazmania_1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-11-2010, 11:07 PM
  5. Please Help Front Left ABS Speed Sensor
    By idealsam in forum Polo - Derby - Lupo - Fox
    Last Post: 30-07-2009, 09:57 AM
