Thread: Check engine light on and engine vibrating when ignition turned off
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Check engine light on and engine vibrating when ignition turned off
    Sep 2012
    Romford, UK
    @Crasher Thank you very much for your help with fixing this problem.
    I finally got some time to replace the inlet manifold today. I ordered a VDO one online, but they sent a Continental, guess it should be ok. I noticed there is little bit of oil in the turbo boost pipe and EGR valve. Is this expected? I wiped both before fitting the inlet manifold.
    Once replaced, the judder when stopping the car is gone and also overall driving feels smoother. I cleared the code/check engine light, and it didn't come back on after a 15min drive on the highway.
    One little issue I faced is when tightening the screws, I wasn't able to find the right torque wrench. I checked online that the screws should be tightened to 10nm. I only had a 28nm (min setting) torque wrench, so I turned them fairly tight without reaching 28nm, but not sure what torque I applied. Do I need to get a 10nm wrench and make sure they are all 10nm?
  2. Re: Check engine light on and engine vibrating when ignition turned off
    131 Post(s)
    1973 Post(s)
    Continental is VDO. I just nip them up, I have been doing it so long I have a torque wrench built into my wrist.
  1. Question no crank, glow-plug light blinking and check engine light on.
    By rayrowie in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 26-03-2016, 02:17 PM
  2. A3 Check Engine Light
    By Tony Soprano in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-11-2009, 09:44 PM
  3. Please Help 52 reg 1.4 16v Lupo SE has EPC light, Engine check light and stiff brake pedal
    By robbig in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 10:45 PM
  4. Engine Management light turned on??
    By Primo1000 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-02-2008, 09:01 PM
  5. check engine light
    By bluejayway in forum Archive posts
    Last Post: 27-11-2007, 06:29 PM
