Thread: Audi A7 BiTDI poor mpg
Results 1 to 10 of 13
  1. Audi A7 BiTDI poor mpg
    May 2012
    Manchester
    9 Post(s)
    Hey guys,
    so i have a 2016 A7, and im getting around 350 miles from a full tank (of premium shell V power) and approx 22-25mpg local and a max of 30mpg on the motorway. Is this to be expected? I really did expect abit more 40ish on the motorway at least. Im not really heavy footed and even if i drive like a nun im struggling to get anything over 30. Thoughts?
  2. Re: Audi A7 BiTDI poor mpg
    Near Blackpool
    48 Post(s)
    I get around 40 if I drive like a nun and 30 with city/spirited driving. 3.0 v6 tdi fwd.
  3. Re: Audi A7 BiTDI poor mpg
    May 2012
    Manchester
    9 Post(s)
    Damn! The car has been serviced with a oil, filter and air filter change. The only other thing i can think of would be the fuel filter which was changed by audi in 2019 apparently. Surely the Bitdi cant be that much more thirsty?
    2008 Audi A6 C6 S-Line Saloon, 2.0 Diesel with Multitronic Gearbox. BRE engine code and remapped to 170BHP (Stock was 140) Has 85k on the clock
  4. Re: Audi A7 BiTDI poor mpg
    Near Blackpool
    48 Post(s)
    More turbos means more fuel in afraid! My 2006 A3 2.0 140bhp still gets 55mpg on the motorway
  5. Re: Audi A7 BiTDI poor mpg
    Nov 2019
    Cardiff, Wales
    18 Post(s)
    My 2020 S7, 3.0L V6 Twin Turbo 349BHP, gets 50+ cruising at 70 on the ACC but more “fun” driving, usually clocks in around the 30-35 mark???
  6. Re: Audi A7 BiTDI poor mpg
    May 2012
    Manchester
    9 Post(s)
    wow really? thats mental. mine is a 2016 so an older generation. i would expect 40 on the motorway from mine though. not sure if something needs replacing
  7. Re: Audi A7 BiTDI poor mpg
    Nov 2019
    Cardiff, Wales
    18 Post(s)
    Oh, and that’s on regular diesel by the way. I can’t say I’ve tried the V-Power stuff!
    Typically, out of a maybe 70 litre tank I get about 500-520 miles between fills.
  8. Re: Audi A7 BiTDI poor mpg
    May 2012
    Manchester
    9 Post(s)
    okay so just done a VCDS scan below and there are a few errors on my car. do any of you think they could be related?
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    28-HVAC, Rear -- Status: Malfunction 0010
    30-Special Function II -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    82-Heads Up Display -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    AC-Reductant Control -- Status: OK 0000
    C0-Act. for Ext. Noise -- Status: OK 0000
    Address 01: Engine (J623-CVUA) Labels:. 059-907-401-V2.clb
    Part No SW: 4G0 907 589 F HW: 4G0 907 589 B
    Component: 3.0BTD EDC17 H23 0004
    Revision: 54H23---
    Coding: 1A2A4032252603030800
    Shop #: WSC 01286 386 08256
    ASAM Dataset: EV_ECM30BTD0114G0907589F 001004
    ROD: EV_ECM30BTD0114G0907589F.rod
    VCID: 377D9EDB8E4D8D3332-8062
    1 Fault Found:
    9647 - Reductant Injector Valve (Bank 1)
    P208E 00 [096] - Stuck Closed
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
    Part No SW: 4G0 927 158 AK HW: 0BK 927 156 AM
    Component: 0BK 30RTDIRDW H19 1009
    Revision: --H19---
    Coding: 000001
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL551211 002022
    ROD: EV_TCMAL551211_002_AU48.rod
    VCID: 77FD5EDBCECD4D33F2-8022
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
    Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
    Component: ESP9 Premium H01 0530
    Revision: -------- Serial number: --------------
    Coding: 49A79E4392E579C29B00
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ESP9BOSCHAU57X 004018
    ROD: EV_ESP9BOSCHAU57X.rod
    VCID: 4189F003D089C3838C-8014
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
    Component: BCM2 2.0 H61 0824
    Revision: 00002001
    Coding: 01BA704E000000000000
    VCID: 7CF741F7FFEB6E6B9F-8028
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Serial number: 3216000104936004
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
    Component: KLIMA 4 ZONEN H14 0113
    Serial number: 26051600040238
    Coding: 36231178350000
    ASAM Dataset: EV_AirCondiComfoUDS 003008
    ROD: EV_AirCondiComfoUDS_003.rod
    VCID: 63C51A8B6A55B193BE-8036
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
    Part No SW: 4H0 907 063 GG HW: 4H0 907 063 AG
    Component: BCM1 2.0 H20 0368
    Revision: 14020001 Serial number: 00001354826101
    Coding: 0105C01440349FE0410140C3800018000F9DC30A2F08020100 0008946100130200400000090000
    VCID: 73E56ACBD2B52113CE-8026
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS57X 160407 H38 0080
    Serial number: 160412125115
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0004
    Serial number: 61887486
    Coding: 02006E
    Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
    Component: E1 - LDS H07 0044
    Serial number: 17 05 2016 00001673
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0005
    Serial number: ED39C03800PAG0MUFU01
    Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
    Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
    Component: PARKHILFE PLA H06 0080
    Revision: -------- Serial number: 56261614500404
    Coding: B81310
    ASAM Dataset: EV_EPHVA2CAU64X0000 001014
    ROD: EV_EPHVA2CAU64X0000.rod
    VCID: 366393DF8947743B29-8062
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
    Component: Airbag10.43 H82 0086
    Revision: -------- Serial number: 003P1009ZX8S
    Coding: 30333046313130313235554A305234473853
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 3B7582EBB265A953D6-806E
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB405P43HCSA0FQ
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 3585HRB405942AGAE1L0
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 3515JRB400O570QKO8T3
    Passenger side rear thorax airbag crash sensor:
    Serial number: 3525JRB400O56VU09OVL
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB40105735EB21A
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB4016572MGR9DR
    Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
    Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
    Component: Lenks.Modul H06 0005
    Revision: C0068538 Serial number: 90862PEG001BT
    Coding: 000034
    VCID: 3B7582EBBA65A953D6-806E
    Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
    Component: E221 - MFL H08 0010
    Serial number: 24 05 2016 E0067679
    Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G8 920 987 R HW: 4G8 920 987 R
    Component: TDieGb H14 0225
    Revision: 11001108 Serial number: 658280516596022
    Coding: 33AF05020B432600010100
    ASAM Dataset: EV_RBD4K 004060
    ROD: EV_RBD4K_AU57.rod
    VCID: 489FED27F3B3F2CB4B-801C
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 4G8 907 468 H HW: 4G8 907 468
    Component: J533--Gateway H15 0096
    Revision: -------- Serial number: 00000002260265
    Coding: C0CD078118
    ASAM Dataset: EV_GatewPkoUDS 002000
    ROD: EV_GatewPkoUDS_002_AU57.rod
    VCID: 3D718CF3AC71A763E8-8068
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
    Component: J367-BDMHella H10 9070
    Serial number: 4362640204
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
    Component: J532_DCDCStab H23 0022
    Serial number: 1603190000000000013C
    Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
    Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
    Component: KLIMA FOND H08 0113
    Serial number: 27051600041528
    Coding: 22
    ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
    ROD: EV_ClimaContrUnitRearUDS_003.rod
    1 Fault Found:
    0075 - Button or Switch in Operating Unit
    B10C7 07 [008] - Mechanical Failure
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 240
    Mileage: 85989 km
    Date: 2021.07.10
    Time: 11:25:47
    Outside temperature: 23.5 °C
    Left rear vent temperature: 15.9 °C
    Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
    Part No SW: 4H0 907 440 HW: 4H0 907 440
    Component: STS H06 0030
    Revision: S0H06000 Serial number: 00000000091094
    Coding: 01010101000000000001000202
    VCID: 64C71997675BB6AB47-8030
    Address 36: Seat Mem. Drvr (J136) Labels: None
    Part No SW: 4G8 959 760 HW: 4G8 959 760
    Component: MEM-FS H03 0157
    Revision: AA000000 Serial number: 00000200883302
    Coding: 0078130000006001000001010101102030303232203232
    VCID: 77FD5EDBC6CD4D33F2-8022
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
    Component: SARA 6D H04 0056
    Revision: -------- Serial number: EJ1BPA820BL9PR
    ASAM Dataset: EV_SARA2 005012
    ROD: EV_SARA2.rod
    Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
    Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
    Component: TSG FA H03 0511
    Coding: 011C56034E21620002080402
    VCID: 479DEE1BF6ADFDB342-8012
    Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
    Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
    Component: RCevo H54 0202
    Revision: 00000001 Serial number: 0000924230
    Coding: 101100010001
    ASAM Dataset: EV_RCEPS 106007
    ROD: EV_RCEPS_106.rod
    VCID: 3A7B87EFBD5F905BCD-806E
    Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0405577862
    Coding: 013F0622A0B9B800C3200A8400010D47000000000000000000 0000000000
    Subsystem 1 - Part No: 4G0 951 177 A
    Component: Sensor, DWA 005 0002
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
    Component: Dachelektroni H10 0100
    Serial number: 0000000AP00021287656
    Coding: 010000
    Subsystem 4 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
    Component: HSP-SG H11 0031
    Serial number: WA124026000021866627
    Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
    Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
    Component: TSG BF H03 0511
    VCID: 4683E31FF1A7E4BBB9-8012
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
    Component: EPB-4 H05 0017
    Revision: -------- Serial number: 00000001861027
    ASAM Dataset: EV_ParkiBrake 001029
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 3169A0C3602953037C-8064
    Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
    Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
    Component: MxB-ECU 001 0100
    Coding: 05FE02202A130200
    ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
    ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
    VCID: 3467A9D79F3B662B17-8060
    Left LED Headlamp Power Output Stage 1:
    Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
    Component: LED LeiMo li. H07 7570
    Coding: E02100
    Right LED Headlamp Power Output Stage 1:
    Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
    Component: LED LeiMo re. H07 7570
    Coding: E02100
    Power module 1 for left matrix headlamp:
    Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
    Component: MxB LeiMo li. H03 0031
    Coding: E02100
    Power module 1 for right matrix headlamp:
    Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
    Component: MxB LeiMo re. H03 0031
    Coding: E02100
    Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
    Part No SW: 4G1 035 021 G HW: 4G1 035 021 D
    Component: MU-H-LND-EU 052 0910
    Serial number: A733E0G7500598
    Coding: 017503010000000013111102000A00332F000CE7F1700100DF
    ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
    ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
    VCID: 1E336B7F01B7DC7BD1-804A
    Data carrier:
    Subsystem 1 - Part No SW: V03 959 802 DE HW: -----------
    Component: ECE 2019 --- 0175
    Serial number: --------------------
    Multimedia System 1:
    Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
    Component: DU8 C7 SV H63 0007
    Serial number: AUZ8Z9GY80569U
    Multimedia system control head:
    Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
    Component: E380 BDT C7 H20 0250
    Serial number: 90349PEI0007X
    Compact disc data bank:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote2 --- 1013
    2 Faults Found:
    3077 - Telephone baseplate
    B1051 13 [008] - Open Circuit
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 242
    Mileage: 85322 km
    Date: 2021.07.01
    Time: 16:42:16
    Voltage terminal 30: 12.5 V
    3086 - Antenna for Telephone Mount
    B1564 01 [008] - Electrical Failure
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 11
    Reset counter: 242
    Mileage: 84851 km
    Date: 2021.06.20
    Time: 17:53:09
    Voltage terminal 30: 14.8 V
    Status of telephone-Antenna diagnostic: OK
    Status of telephone-Telephone baseplate diagnostic: not connected
    Status of telephone-Handset in handset holder (cradle): not selected
    Status of telephone-Handset holder (cradle): not connected
    Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
    Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
    Component: TSG HL H03 0511
    Coding: 010814024021620002080002
    VCID: 4999E823E0B90BC354-801C
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 241
    Mileage: 86133 km
    Time Indication: 0
    Date: 2021.07.14
    Time: 07:55:58
    Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
    Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
    Component: Anhaenger H14 0137
    Revision: 7B001002 Serial number: 0393305026
    Coding: 0100000202000000
    ASAM Dataset: EV_TrailFunctGener2Hella 001005
    ROD: EV_TrailFunctGener2Hella_VW26.rod
    VCID: 3365AACB9A3561130E-8066
    Address 6C: Back-up Cam. (J928) Labels:* None
    Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
    Component: TopView H09 0361
    Revision: 11001001 Serial number: 82330JG0173639
    Coding: 0216000001000100000102000000
    ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
    ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
    VCID: 2F6DA6BB761D45F36A-807A
    Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
    Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
    Component: HDSG-Modul H14 0049
    Revision: 11014001 Serial number: 129600418
    Coding: 0A3305C002
    ASAM Dataset: EV_HDSGAu573 001022
    ROD: EV_HDSGAu571.rod
    VCID: 4581E413C4A1EFA3B0-8010
    Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
    Component: TSG HR H03 0511
    Address 82: Heads Up Display (J898) Labels:* None
    Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
    Component: HeadUpDisplay H08 0306
    Revision: 00000000 Serial number: 00000000000000
    Coding: A20000
    ASAM Dataset: EV_HUDContiC7 001027
    ROD: EV_HUDContiC7.rod
    VCID: 3E738BFFA177BC7BF1-806A
    Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
    Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
    Component: DPC-SG H27 0081
    Revision: -------- Serial number: 262130025421000
    Coding: 60140000
    ASAM Dataset: EV_OnBoardCamerDPC 001007
    ROD: EV_OnBoardCamerDPC.rod
    VCID: 2C57B1B7470B3EEB4F-8078
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 4G0 907 159 D HW: 4H0 907 159 A
    Component: SAS-GEN 2 H07 0007
    Serial number: 160413203644
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 2E53BBBF71174CFB61-807A
    Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
    Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
    Component: SCR-Stg-G2 H10 0013
    Revision: 00000000 Serial number: 161190723
    ASAM Dataset: EV_RDCMA00100 008040
    ROD: EV_RDCMA00100.rod
    Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
    Part No SW: 4G0 907 160 E HW: 4G0 907 160 B
    Component: SAS-GEN 2 AGA H09 0011
    Serial number: 160426202253
    ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
    ROD: EV_ActuaForExterNoiseUDS.rod
    VCID: 275D4E9B5EED1DB3A2-8072
    End-------------------------(Elapsed Time: 06:13)--------------------------
  9. Re: Audi A7 BiTDI poor mpg
    Near Blackpool
    48 Post(s)
    Clear them and drive it again for a week and see what comes back, my A7 comes up with all kinds of weird and wonderful dtcs that never come back.
  10. Re: Audi A7 BiTDI poor mpg
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Clear the codes, the one that would concern me the most of your list is the Reductant Valve closed one, keep an eye on that one.
    As for mileage, on my 2015 3.0Tdi Allroad I get 550 miles to a tank on the CRTE engine, I also mainly run in comfort mode and use Costco Premium Diesel.
    Change your fuel filter, it can make a difference, its beneath the drivers seat above the under body protection, takes 20 mins to swap out.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  1. New Audi A7 BiTDI purchase
    By k114l3d in forum A7 - S7
    Last Post: 06-05-2021, 11:03 AM
  2. Audi bitdi - what to look for.
    By franky in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-09-2019, 07:19 PM
  3. New Owner Audi A6 BiTDI
    By PeterPan114 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-02-2016, 05:25 PM
  4. AUDI A6 3.0 Tdi to A6 Bitdi or A8 3.0 Tdi
    By colin53 in forum A8 - S8 - V8
    Last Post: 24-11-2015, 06:59 PM
  5. AUDI A6 3.0 Tdi to A6 Bitdi or A8 3.0 Tdi
    By colin53 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-11-2015, 04:28 PM
