Thread: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
Results 11 to 20 of 28
  1. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #11
    Mar 2018
    Liverpool, UK
    If you can see flow it is unlikely to be the water pump, which make of thermostat did you fit?
    Circoli
    Circoli Thermostat | Euro Car Parts
  2. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #12
    67 Post(s)
    1214 Post(s)
    I would start by fitting the correct one Circoli Thermostat | Euro Car Parts
    A petition has been started to allow the use of synthetic fuels when they become available, this may allow the continued sale of ICE vehicles post 2030 and the use of classic vehicles well into the future… Their use may even be able to rival electric vehicles given the chance. Please sign this petition IF you feel the infernal combustion engine has a future if sustainable fuels are made available
    https://petition.parliament.uk/petitions/588774
  3. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #13
    Mar 2018
    Liverpool, UK
    Thanks mate, I used the car registration to get the original one! Seems I'll have to be careful in future.
  4. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #14
    Mar 2018
    Liverpool, UK
    Here’s the multimeter reading from the G62 socket. So there’s something going to the sensor
  5. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #15
    Mar 2018
    Liverpool, UK
    However as you can see, the temp sensor reading is incredibly erratic. If the car has a reading surely this means it’s either the sensor or ECU is the issue?
  6. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #16
    67 Post(s)
    1214 Post(s)
    I have never seen an ECU show the temp like that, it has to be the ECU.
  7. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #17
    Mar 2018
    Liverpool, UK
    It would seem the most likely wouldn't it, ruled out a dodgy connection. A quick scan and I've seen some plug and play BKD ECU's online, would you recommend this?
  8. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #18
    67 Post(s)
    1214 Post(s)
    I can see the point and can’t really imagine the lack of security is going to be an issue but I have given up with used parts almost entirely as I have had so much trouble and lost so much time but replacing your ECU the correct way would be daft money, around £1800 so on an old Fuel Of The Devil car, not sensible. We had an A3 in on Friday of the same vintage and it was ******* out, messed with and basically FUBAR so we advised him to scrap it; in fact that was two older Diesel cars we advised owners to scrap that day… apparently scrapping 12 year old cars is going to “save the planet”, my own 18 year old car is ULEZ compliant and in perfect condition with 200k miles on it and is going nowhere!
  9. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #19
    Mar 2018
    Liverpool, UK
    I can see the point and can’t really imagine the last of security is going to be an issue but I have given up with used parts almost entirely as I have had so much trouble and lost so much time but replacing your ECU the correct way would be daft money, around £1800 so on an old Fuel Of The Devil car, not sensible. We had an A3 in on Friday of the same vintage and it was ******* out, messed with and basically FUBAR so we advised him to scrap it; in fact that was two older Diesel cars we advised owners to scrap that day… apparently scrapping 12 year old cars is going to “save the planet”, my own 18 year old car is ULEZ compliant and in perfect condition with 200k miles on it and is going nowhere!
    Well it’s running at a normal temperature, I’ve got a couple of genuine sensors which I’ll fit with the proper thermostat on Tuesday. Might just leave it at that then, would a remap do anything?
    Ha. For an electric vehicle which will no doubt create more emissions in making the batteries etc than keeping an older one going would...
  10. Re: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    #20
    67 Post(s)
    1214 Post(s)
    We are being fed a pile of **** over electric cars but the “die is cast” and there is nothing anyone can do about us handing ourselves to China on a plate… I hope I live long enough to see the protagonists of our demise swing.
  1. T5 2.5 AXD Engine. Location of coolant temp. sensor.
    By Moose man in forum The Commercial Range
    Last Post: 22-07-2011, 10:17 PM
  2. engine coolant temp sensor fault..mk5 golf 1.4l
    By achiman in forum VCDS - Help Requests
    Last Post: 13-02-2009, 08:23 PM
  3. Engine Coolant Temp Sensor - where?
    By clarky_two in forum Chat - Anything with wheels
    Last Post: 11-12-2008, 11:13 AM
  4. Engine Coolant Temp Sensor
    Last Post: 09-12-2008, 05:48 PM
  5. Engine Coolant Temp Sensor
    By doug.howsie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2007, 02:00 PM
