Thread: VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
Results 1 to 10 of 28
Threaded View
  1. VW Golf MK5 2.0 GT TDI (BKD) G62 Engine Coolant Temp Sensor
    Mar 2018
    Liverpool, UK
    Hi chaps,
    I've had a check engine light come on. I've used my carista app which gave me a P0117
    I have issues with a long crank when starting the car. However, I've changed the Engine coolant temperature sensor and it still throws up this code (even after a reset)
    If I disconnect the plug from the sensor it throws up P0118 (And starts easier)
    The app says the Engine coolant temp is 139 degrees (Obviously wrong)
    I'm at a loss what to do?
    (Thanks in advance)
  1. T5 2.5 AXD Engine. Location of coolant temp. sensor.
    By Moose man in forum The Commercial Range
    Last Post: 22-07-2011, 10:17 PM
  2. engine coolant temp sensor fault..mk5 golf 1.4l
    By achiman in forum VCDS - Help Requests
    Last Post: 13-02-2009, 08:23 PM
  3. Engine Coolant Temp Sensor - where?
    By clarky_two in forum Chat - Anything with wheels
    Last Post: 11-12-2008, 11:13 AM
  4. Engine Coolant Temp Sensor
    Last Post: 09-12-2008, 05:48 PM
  5. Engine Coolant Temp Sensor
    By doug.howsie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2007, 02:00 PM
