Thread: Any way of checking fuel injectors with VCDS on Audi A4 B6 2003 3.0 v6 petrol
  1. Any way of checking fuel injectors with VCDS on Audi A4 B6 2003 3.0 v6 petrol
    Liverpool
    11 Post(s)
    As above, trying to locate the cause of a misfire in 1 of the 6 cylinders, have replaced plugs and coil packs and still a misfire in cylinder 6. Is there an option on VCDS to check their operation or to eliminate the injector as the cause?
  2. Re: Any way of checking fuel injectors with VCDS on Audi A4 B6 2003 3.0 v6 petrol
    1837 Post(s)
    No, do a compression check
  3. Re: Any way of checking fuel injectors with VCDS on Audi A4 B6 2003 3.0 v6 petrol
    Liverpool
    11 Post(s)
    Thanks Crasher, and thanks just seen your reply to my original post
  1. Checking Oil Changes etc with VCDS
    By Q7quattro in forum Audi A6 - C8 Forum - 2019 -
    Last Post: 28-02-2021, 04:35 PM
  2. Audi 2.0 tdi fuel injectors -measuring blocks
    By herts62 in forum VCDS - General Questions
    Last Post: 11-03-2011, 02:08 PM
  3. Question fuel injectors for Audi 80 B4,ABK engine
    By Docho in forum 80 - 90
    Last Post: 28-03-2010, 07:24 PM
  4. Question fuel injectors for Audi 80 B4,ABK engine
    Last Post: 13-01-2010, 11:52 AM
  5. Checking Oil Level - Polo 1.4 16V 2003
    By Omni in forum Polo - Derby - Lupo - Fox
    Last Post: 25-02-2008, 07:30 PM
