Thread: New Battery Time
Results 1 to 10 of 11
  1. New Battery Time
    Jan 2016
    Winchester Hants
    29 Post(s)
    My CTEK MXS 5 is telling me I might be needing a new battery soon.
    It has the original Varta 7P0 945 105 12V 68Ah 380A DIN 680A EN/SAE/GS AGM Stop/Start fitted.
    This precise model does not come up when Googling but more 096 models.
    What's a good direct replacement, Varta, Bosch, Exide (expensive) without requiring any software programming.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 68K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  2. Re: New Battery Time
    134 Post(s)
    2014 Post(s)
    7P0 945 105 would be something to do with the rear lights of a Touareg 2 if it was a good number, the battery would be 7P0 915 105 and now 000 915 105 CC by my reckoning. I had been using Yuasa as TPS were pushing them but I had multiple failures of the EFB and AGM type, I put a Bosch in Mrs Crasher Polo and that failed after 6 months and now we solely fit Varta OE “Like-for-like” so a Varta 570901076D852 in your case and yes, a 096 type going by the old British Battery Manufactures Association system.
  3. Re: New Battery Time
    Jan 2016
    Winchester Hants
    29 Post(s)
    Many thanks Crasher, looks just the job.
  4. Re: New Battery Time
    Jan 2016
    Winchester Hants
    29 Post(s)
    It may be getting close as the charger now requires using recon during most charges. Are there any special things I must do before removing the old and fitting the new.
  5. Re: New Battery Time
    134 Post(s)
    2014 Post(s)
    If it is a stop start car it should be coded into the battery monitoring unit.
  6. Re: New Battery Time
    May 2012
    Everywhere
    308 Post(s)
    UMEL is the engine still starting well ?
  7. Re: New Battery Time
    Jan 2016
    Winchester Hants
    29 Post(s)
    Yes and it is stop start
  8. Re: New Battery Time
    May 2012
    Everywhere
    308 Post(s)
    So starting well and stop start is intermittent / stopped working ?
  9. Re: New Battery Time
    Jan 2016
    Winchester Hants
    29 Post(s)
    Starting well and no issues with S/S. sounds like I should keep it a while longer.
  10. Re: New Battery Time
    Jan 2016
    Winchester Hants
    29 Post(s)
    If and when the time comes, can I assume my Ancel VD500 is no good for the recoding.
  1. Question Time For a New Battery 2.0 Passat BMT
    By Steven715 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 28-11-2020, 02:10 PM
  2. Battery time
    By daveplyjeep in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-08-2014, 02:17 PM
  3. Replies: 25
    Last Post: 21-04-2014, 06:31 PM
  4. coolant fans on all the time and battery dies
    By kangtdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2008, 11:46 PM
  5. new battery time?
    By beaucostil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-12-2007, 10:59 PM
