Thread: Bleeding ABS control unit on A4 B5
  1. Bleeding ABS control unit on A4 B5
    Mar 2016
    Minervois, France
    53 Post(s)
    I notice that some cars have a procedure, done after normal bleeding, where a scan tool is used to bleed the ABS control unit. I assume this is to remove air or contamination trapped in the unit's pump and valves system, which can not be removed by normal bleeding. Here is an example How to bleed brakes with a scan tool. No pumping necessary - YouTube
    I would like to know whether this is possible on my car, which has a Bosch 5.0 system.
    Is this procedure necessary only on certain cars, or on any car when a control unit is replaced or air has got into it?
    Is some fluid always trapped in ABS control units when changing fluid, but is insignificant?
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  2. Re: Bleeding ABS control unit on A4 B5
    1837 Post(s)
    The Bosch pumps don't have that feature.
  1. MMI control unit
    By prh47bridge in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-04-2018, 09:08 AM
  2. ABS control unit
    By markgrff17 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2012, 06:36 PM
  3. Control Unit
    By joannelut in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2010, 10:28 PM
  4. A4 ILM control unit?
    By cosmo2978 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-04-2008, 09:57 AM
  5. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
