Thread: Failing 8valve 2.0tdi
  1. Failing 8valve 2.0tdi
    Jul 2021
    Norway
    I know this is cinda a repost but iam getting desperate. Need to order parts today if I will have them delivered befoore next weekend. I have some problems with my passat. It stopped a lot and I needed to crank 5/8 times for up to 20 seconds for it to start. I had a code p1674,and white smoke when it started. but it said on the interweb that it was probably cam sensor under the timing belt. I changed it and everything seemed fine.
    Until I drove it for 40 min and it stopped agean. 1 gear maybee 1500 rpm. Started after 4/5 long cranks. Drove it furter to the city where it stopped 2 Moore times, waiting for rigth of way. Neutral 850 rpm. Altso now I needed a lot of cranking.
    After this I just revved the engine when I had to stop and I managed to drive 2 hours home.
    Car now shakes a little in idle.
    Today I got yellow check engine ligth. Only with ignition on. Dissappear when I start.
    When I drive at even speed sometimes my rpm falls from say 1800 to 1600 for half second and goes straight back up. (probly this that make the car stall in idle )
    EQ_RATB1 S1 showed with red numbers at a value over 3.000 in idle with everything else in black writing on the scan tool
    I have had the code for cylinder 3 misfire 1 time. But I think this is becouse I managed to stretch the gasket on the intercooler air hose. I have ordered a new one.
  2. Re: Failing 8valve 2.0tdi
    1840 Post(s)
    The MIL should (must) come on with the ignition, do you still have code P1674 and in which controller? Which code reader are you using?
  3. Re: Failing 8valve 2.0tdi
    Jul 2021
    Norway
    Iam using a autel mst505. I know that check engine ligth normally comes on with the ignition. But it has always dissappear after a second or something. But now it stays on until I Crank the car
  4. Re: Failing 8valve 2.0tdi
    Jul 2021
    Norway
  5. Re: Failing 8valve 2.0tdi
    1840 Post(s)
    I can't check on our 2009 estate as it is out on loan. You need a better VAG specific code reader, the one you are using is possibly giving you incorrect information.
  1. Please Help non starting 8valve gti
    By seanw in forum Golf MK2 - 1984 - 1992
    Last Post: 03-08-2010, 12:51 PM
  2. Turbo for my 2.0l 8valve???
    By nane4u in forum 8v - Engine
    Last Post: 01-04-2010, 07:07 PM
  3. Mk2 8valve GTI
    By Baker9 in forum Golf MK2 - 1984 - 1992
    Last Post: 11-10-2009, 06:08 PM
  4. 8valve
    By jetta in forum New Member Introductions
    Last Post: 28-09-2009, 07:58 PM
  5. Mk3 8valve handbrake light on permantly
    By veedub76 in forum Golf MK3 - 1993 - 1999
    Last Post: 29-06-2009, 06:04 PM
