Thread: Sudden surging , bucking popping and stalling . help
  1. Sudden surging , bucking popping and stalling . help
    Jul 2011
    Ruan Minor
    Hi All, hoping you help me with my 2013 amarok 2.0 biturbo 8 speed auto .
    my symptoms are i start the truck and drive could be 200m or 100m who knows at around 1500 rpm very light throttle light load... then whammo it starts to take off/ surge all by its self with no input from the driver. very scary..
    it will surge buck then stall along with popping sounds from the turbos. starts back up fine and no warning lights.
    plugged vcds in and no faults found with engine .
    so i ran a turbocharger test from basic settings twice and got this fault once ( never by driving it though )
    Address 01: Engine Labels: 03L-906-022-CFC.CLB
    Control Module Part Number: 03L 906 012 AF HW: 03L 907 309 AC
    Component and/or Version: R4 2,0L EDC X23 4433
    Software Coding: 012A4012232600080001
    Work Shop Code: WSC 07456 790 50316
    ASAM Dataset: EV_ECM20BTD01103L906012AF 001008 (VN81)
    ROD: EV_ECM20BTD01103L906012AF_001.rod
    VCID: 68DE803C9373DA0622-803C
    1 Fault Found:
    11873 - Turbocharger Inlet Valve
    P22D2 00 [032] - Stuck Open
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 114440 km
    Date: 2096.14.30
    Time: 20:50:35
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 68 °C
    Intake air temperature: 37 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 12.500 V
    Unlearning counter according OBD: 40
    Actuator for low press turbocharger: activation: 11.18 %
    Bypass valve f high press turboch turbine inlet: actual value: 7.14 %
    Bypass valve f high press turboch turbine inlet: offset closed: 4.48 %
    Bypass valve for high press turboch turbine inlet: activation: 95.00 %
    Bypass valve for high press turboch turbine inlet: uncond volt: 3401.6 mV
    Readiness: 0 0 0 0 X
    Address 01: DTCs cleared
    i took the air filter box off and it had a white soot / smoke residue inside is this caused by the inlet valve being open when it should not be ?
    has anyone had the fault code or experienced surging bucking popping stalling without input from the driver ??
    i cannot drive the truck as it is ..seems weird that no MIL or warning lights show up..
    please help ! many thanks Richard
  2. Re: Sudden surging , bucking popping and stalling . help
    Jul 2011
    Ruan Minor
    bump ... would i be best to repost in another area of this forum for an answer ??
  1. Please help A4 B6 bucking and then stalling at the lights
    By cmulindwa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-10-2018, 10:03 AM
  2. Bucking Skoda Octavia Please Help!!!
    By 220sugars in forum Octavia
    Last Post: 28-07-2013, 11:37 PM
  3. Golf MK4 lurchin/bucking
    By Yelloperil in forum Golf MK4 - 1999 - 2004
    Last Post: 17-12-2008, 10:48 PM
  4. audi 80 tdi bucking jerking
    By micheal balbrig in forum 80 - 90
    Last Post: 30-12-2007, 06:56 PM
  5. 1998 golf gti stalling and surging
    By patfaulkner in forum Golf MK3 - 1993 - 1999
    Last Post: 12-10-2007, 08:44 AM
