Thread: Mk5 BKD Wobble/Shake at higher speeds
Results 1 to 8 of 8
  1. Mk5 BKD Wobble/Shake at higher speeds
    Jul 2016
    United Kingdom
    Hi guys,
    Having an issue with my Golf, basically it started with a lightish vibration at higher speeds (60-70+) I lived with it for a little while until it killed my wheel bearing, up on inspection my driveshaft boot was split and some grease had come out but not a huge amount. By this time it had turned into a bit more of a noticeable rumbling shaking feeling under the drivers footwell.
    I decided to replace the Wheel bearing and the outer CV joint, but the rumbling continued, I then tried replacing the whole driveshaft but this didn’t improve things either so I’m now thinking it’s not the driveshaft at all.
    I’m going to try rotating the wheels front to back tomorrow and see how that is but honestly I don’t think it feels like unbalanced wheels.
    It’s kinda driving me mad now and it sometimes causes the turbo to cut out under load as it feels like it’s struggling to accelerate the faster you’re going.
    Any ideas what could be going on ?
  2. Re: Mk5 BKD Wobble/Shake at higher speeds
    Dec 2014
    Bedford
    42 Post(s)
    Flywheel?
    Sent from my SM-G970F using Tapatalk
  3. Re: Mk5 BKD Wobble/Shake at higher speeds
    Jul 2016
    United Kingdom
    Quote Originally Posted by FLAPPERJACK76 View Post
    Flywheel?
    Feels like it’s something closer to the wheels to me, it’s had new clutch and flywheel less than 20k ago
  4. Re: Mk5 BKD Wobble/Shake at higher speeds
    1840 Post(s)
    Some of the early ones had a two piece right hand drive shaft, is yours?
  5. Re: Mk5 BKD Wobble/Shake at higher speeds
    Jul 2016
    United Kingdom
    Flywheel?
    No it’s a single piece, 2008 model
  6. Re: Mk5 BKD Wobble/Shake at higher speeds
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Have you checked the suspension?
    Any play in any of the ball joints? Or wishbone rubber mounts? Are they good? Not perished or torn?
    Are the wheels balanced correctly?
    Is the tracking spot on?
    Tyres good? And correct size and matching?
    Is the spring on the strut ok? Strut leaking? Top mount ok?
    Wheel bolts torqued up correctly? Mating faces cleaned?
    Might also be a warped disc or bad calipers?
  7. Re: Mk5 BKD Wobble/Shake at higher speeds
    Jul 2016
    United Kingdom
    So I rotated the wheels front to back today, didnt change anything so I don’t think it’s an issue with the wheels, checked them all for buckles or missing wheel weights etc everything looks in good order.
    Took it for a long drive today down the dual carriageway and noticed after driving for a while the steering felt like it stiffened up even after coming back down to lower speeds which is strange, something is obviously not right.
    I’m going to check over the front end suspension again tomorrow hopefully, I did already check for play in the wheels and couldn’t find anything but I could do with checking all the bushes etc so I’ll give that a go and report back.
  8. Re: Mk5 BKD Wobble/Shake at higher speeds
    Jul 2018
    8 Post(s)
    Perhaps the steering rack is bad?
    Have you done a scan for fault codes?
  1. Please Help Back end twitching whilst accelerating and cornering at higher speeds
    By james.keiller91 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2016, 12:03 PM
  2. A4s with Higher milages
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2014, 10:30 AM
  3. Engine Wobble/Shake after starting - Warm engine
    By a8starr in forum A8 - S8 - V8
    Last Post: 18-12-2013, 01:39 PM
  4. A6 Quatto Avant - slight wobble at motorway speeds
    By Gareth273 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-11-2013, 09:31 AM
  5. A4 - wobble at slow speeds
    By mkirby1981 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2011, 10:20 PM
