Thread: oil in spark plug holes 3.0 v6 petrol
  1. oil in spark plug holes 3.0 v6 petrol
    Liverpool
    11 Post(s)
    As above, my A4 was running rough so had it scanned by a friend. Misfire on 3 cylinders, so replaced the 3 coil packs and all 6 spark plugs. On removing the plugs, some of the plug holes had traces of oil in them, and, on the old plugs I removed
    Any ideas what it could be? covered 125k, 2003 A4 3.0 v6
  2. Re: oil in spark plug holes 3.0 v6 petrol
    1837 Post(s)
    Small weep from the cams cover seals, just clean it every service. Replacing the cam cover seal usually fails as the covers distort and you end up doing it again with a new cover. Unfortunately it can also be the cam carrier to head sealant face and this is very involved to deal with.
  3. Re: oil in spark plug holes 3.0 v6 petrol
    Liverpool
    11 Post(s)
    Thanks Crasher - Had the gaskets done at a local garage. Since then I've still got a misfire on Cylinder 6. Swapped the coil packs and spark plug with that from cylinder 5, misfire still with cylinder 6. Is there a way of testing an injector? Or any idea what else it could be?
    A colleague uses VCDS and all it comes up with is 'misfire cylinder 6'
  4. Re: oil in spark plug holes 3.0 v6 petrol
    1837 Post(s)
    Compression test.
  5. Re: oil in spark plug holes 3.0 v6 petrol
    Liverpool
    11 Post(s)
    Thanks again Crasher - belated update due to working away. Replaced the other coil packs so 6 new ones and no longer running rough
    all good
  1. APP Spark plug gap
    By David McMahon in forum Leon
    Last Post: 19-07-2014, 12:56 AM
  2. Question A4 3.0 Cab - any particular spark plug?
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-12-2011, 10:39 PM
  3. Oil into my spark plug holes
    By IoanaBan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-03-2009, 12:45 AM
  4. Spark plug gap?
    By Jayc530 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 06:11 PM
  5. A6 Spark plug gap?
    By gooders30 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-08-2007, 06:05 PM
