Thread: A4 B7 AFS Xenon Headlight Module
  1. A4 B7 AFS Xenon Headlight Module
    Aug 2012
    Hartlepool
    Hi All,
    I have an issue with Headlight module on my B7 Cab resulting in the yellow AFS warning on the dash.
    Headlights work perfect, so far I've....
    Ran VCDS scan and the below error was displayed :
    Sunday,27,June,2021,14:51:37:22202
    VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64
    Ross-Tech: Home
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Control Module Part Number: 4F0 910 357 E HW: 4F0 907 357 E
    Component and/or Version: AFS 1 H01 0010
    Software Coding: 0000019
    Work Shop Code: WSC 00672 785 00200
    Additional Info: 8E0941329 AFS-Modul links H03 0020 8E0941329 AFS-Modul rechtsH03 0020
    VCID: 2809F238EEF670EBE73-807C
    1 Fault Found:
    02233 - Left Headlight Power Output Stage (J667)
    014 - Defective - MIL ON
    Freeze Frame:
    Fault Status: 11101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Time Indication: 0
    So, I swapped the module to the other side and the fault moved with it, therefore I know the module is at fault.
    Being an AFS unit, they are expensive to replace, so looking to repair if possible.
    I've stripped the unit and it's nice and clean / dry inside so the issue isn't down to water ingress.
    Can anyone offer any advice on suspect components?
    A bit of a google shows the Capacitor and FET in the output stage are a couple of the most likely causes does anyone have any experience of this or any pointers?
  2. Re: A4 B7 AFS Xenon Headlight Module
    Aug 2012
    Hartlepool
  3. Re: A4 B7 AFS Xenon Headlight Module
    Aug 2012
    Hartlepool
  4. Re: A4 B7 AFS Xenon Headlight Module
    Aug 2012
    Hartlepool
  1. Audi a6 xenon light control module
    By quattrogary in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-09-2018, 01:58 PM
  2. Xenon Headlight Kevelling Control Module
    By bobh6742 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-10-2017, 11:52 AM
  3. A4 - B9 Headlight Xenon or bi-xenon
    By martinbuffleo in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 31-01-2017, 09:56 PM
  4. Audi a4 b7 Bi-Xenon retrofitting conversion & Headlight Range Control Module
    By xpapix in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-02-2014, 09:06 PM
  5. Xenon Range - Internal Control Module Memory
    By conor2949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2010, 12:42 PM
