Thread: No fault codes
  1. No fault codes
    Jun 2021
    Manchester
    Just bought a golf plus with as few little issues. The cruise control, cigarette lighter and rear door lock don't work.
    However, when I plug in my Bluetooth OBD2 scanner I don't get any fault codes. Anyone have any idea why this might be happening?
    Ta
  2. Re: No fault codes
    133 Post(s)
    1992 Post(s)
    That is because the codes are not OBDII and your scanner can't see what the problem is.
  3. Re: No fault codes
    Jun 2021
    Manchester
    Ah, right. That makes sense.
    How would I read the codes then?
    Any recommendations on a scanner that I can buy?
    Ta
  4. Re: No fault codes
    133 Post(s)
    1992 Post(s)
    All I can recommend by use is VCDS.
  5. Re: No fault codes
    Oct 2017
    London
    12 Post(s)
    Door lock will be the motor they always fail. Vcds will show this. For the cruise control I’ve seen the switch on the stalk fail although other issues can stop the cc from working for safety reasons. Again vcds helps a lot.
  1. Two Fault Codes
    By Imran in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2018, 11:10 PM
  2. Question Help with fault codes
    By Nard666 in forum VCDS - Help Requests
    Last Post: 28-09-2017, 09:58 PM
  3. Fault Codes
    By Beagler in forum VCDS - Help Requests
    Last Post: 04-05-2013, 04:12 PM
  4. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  5. Please Help Vag-Com fault codes - Please help
    By audikid in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2009, 04:54 PM
