Thread: Radiator fan on constantly when running
  1. Radiator fan on constantly when running
    Jun 2021
    Hereford
    Hi all,
    I hope I’m posting this in the right place. I have a 2001 b6 saloon with the 2.0 petrol (not fsi), recently the radiator fan (larger, passenger side one) has been kicking in from startup constantly. There’s zero water in the ecu and the fan switches off when the car is turned off. Both coolant temperature sensors have been replaced recently. Does anyone have any ideas what this might be? I was considering changing the fan switch but would rather have it pinned down first before changing parts.
    Forgot to say that the engine temperature dial on the dash isn’t working (or sometimes randomly comes to life then returns to the ‘cold’ position).
  2. Re: Radiator fan on constantly when running
    Jan 2009
    Birmingham
    35 Post(s)
    First thing you should do is get a scan done vcds to see if any codes.
    What make coolant temp sensor did you use because if you temp dial is erratic it could be the coolant sensor if duff.
  3. Re: Radiator fan on constantly when running
    1840 Post(s)
    Probably the radiator fan control unit which is hard wired into the fan harness.
  4. Re: Radiator fan on constantly when running
    Jun 2021
    Hereford
    Thanks for the replies. I had the car scanned a little while ago and it said something about ‘system voltage low’, referring to the cooling system, but I haven’t used the car since. I’ll have to go back to the garage then by the sounds of it to investigate further. Is the fan control unit a tricky job?
  5. Re: Radiator fan on constantly when running
    1840 Post(s)
    Bit of a fiddle, the wires have to be de and re-soldered.
  1. Engine Fan Constantly Running
    By Dave_Bounce in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-03-2013, 02:27 AM
  2. Question Fan running Constantly
    By rwavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2012, 05:23 PM
  3. Radiator fan on constantly
    By paulbl in forum Golf MK4 - 1999 - 2004
    Last Post: 13-11-2011, 09:26 AM
  4. Please Help Sharan Radiator Fan Constantly On !
    By Churchie in forum Touran - Sharan - Caravelle
    Last Post: 07-01-2010, 06:42 PM
  5. Please Help 2003 S4 (B6) fans running constantly
    By adamjwk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2008, 12:26 AM
