Thread: ESP & ABS & HandBrake Warning Lights - VCDS Results
  1. ESP & ABS & HandBrake Warning Lights - VCDS Results
    Feb 2012
    Liverpool
    Hi all,
    I got an error of all these three things simultaneously, and the electric handbrake doesn't obviously work. I did a VCDS scan and I got the following:
    How do I proceed? Change the Rear Left sensor and hope everything else falls in to place?
    Thanks in a advance...
    Address 01: Engine Labels: 059-907-401-BPP.clb Part No SW: 4F5 910 401 HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000SG 0010
    Revision: --H04--- Serial number:
    Coding: 0011322
    Shop #: WSC 66565 257 00032
    VCID: 5EB5C4148981A67B91-800B
    1 Fault Found:
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 -
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 8
    Reset counter: 255
    Mileage: 220862 km
    Time Indication: 0
    Date: 2021.06.25
    Time: 19:20:25
    Freeze Frame:
    RPM: 1386 /min
    Torque: 93.6 Nm
    Speed: 47.0 km/h
    Duty Cycle: 13.9 %
    Voltage: 13.91 V
    Bin. Bits: 00101000
    Torque: 300.3 Nm
    Readiness: 0 0 0 X 0
    Address 03: ABS Brakes Labels: 4F0-910-517.clb
    Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
    Component: ESP8 front H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004491
    Shop #: WSC 05595 210 01865
    VCID: 65C7EBF8ACD7F5A350-8031
    1 Fault Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 220880 km
    Time Indication: 0
    Date: 2021.06.25
    Time: 23:31:38
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0382
    Hex Value: 0x0008
    Hex Value: 0xAC8F
    Hex Value: 0x00FF
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000511
    Shop #: WSC 02324 785 00200
    VCID: 2049BAECF375D08BE3-8075
    1 Fault Found:
    01316 - ABS Control Module
    008 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 248
    Mileage: 220856 km
    Time Indication: 0
    Date: 2021.06.25
    Time: 19:20:23
    Freeze Frame:
    Voltage: 12.94 V
    Count: 231
  2. Re: ESP & ABS & HandBrake Warning Lights - VCDS Results
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    VCDS has detected that the near side rear wheel speed sensor isn't giving the correct signal back to the ABS module.
    First check the rear wheel bearing is ok.
    If ok, change the speed sensor.
    Once fixed, the engine & parking brake fault should just clear.
  3. Re: ESP & ABS & HandBrake Warning Lights - VCDS Results
    Feb 2012
    Liverpool
    Very good methodology, thanks.
    I could have changed the sensor and if I had a faulty bearing the issue would still be there.
    Thanks again!
  1. Measuring Block 23 VCDS - Explanation of results
    By Peter_222 in forum VCDS - General Questions
    Last Post: 30-01-2016, 10:15 AM
  2. Question VCDS O2 sensor aging and cat test results
    By h4l in forum Golf MK4 - 1999 - 2004
    Last Post: 24-10-2015, 03:45 PM
  3. Please Help VCDS Scan results
    By smoggyrich in forum Golf MK5 - 2004 - 2009
    Last Post: 21-04-2014, 08:56 PM
  4. Some VCDS results CCM some are new
    By KieranM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2012, 09:27 PM
  5. Please Help ABS, ESP and Handbrake warning lights coming on!
    By 1958 harry in forum Beetle 2000-
    Last Post: 05-03-2009, 08:12 PM
