Thread: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
Results 1 to 10 of 19
  1. 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    Hi there lovely forum folk!
    The Mrs' 2.0TDi died on the motorway a couple weeks ago, lost all power then engine cut out completely. It was identified as high pressure fuel pump so this has been replaced, however it won't start at all!!
    Got fuel to the rail and to the injectors so the pump is now working (didn't have fuel to the injectors before when cranked) but the bitch won't fire. Turns a treat and makes all the right noises but....nothing! Will fire and run (badly) with easy start sprayed into the inlet but it seems like its not feeling enough?! Does the pump need coding?
    No fault codes on VAG-COM either. Any help massively appreciated! :-c
  2. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    1840 Post(s)
    Which engine code, BKP?
  3. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    Not entirely sure, it’s now away with the mechanic who fitted the pump. It’ll be on the V5 tho, right?
  4. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    Got the engine number CBA 601905.....does this help?
  5. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    1840 Post(s)
    A very early common rail TDI engine, we need some fuel rail pressure data but IF the high pressure fuel pump failed in the usual way, just fitting a new fuel ump is often not enough.
  6. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    What else will/could it need? My T5.1 did something similar, cost a small fortune to rectify!
  7. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    1840 Post(s)
    It is virtually identical, we have a T5 facelift into today running rough with suspected fuel pressure problems, my tech is just scanning it now.
  8. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    According to the mechanic I need three injectors! It’s pretty much a write off at that!
  9. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    1840 Post(s)
    Yes, we see it on a regular basis right across the VAG range with the early common rail, especially the CAYB and C 1.6 units.
  10. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    Are there any VAG group cars that don't have an injection system made of chocolate?!
  1. Question 2009 Mk6 2.0tdi fuel pump??
    By Mickyroo in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2020, 10:33 AM
  2. Question TDI Fuel Pump Failure and Replacement
    By pravens in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-01-2013, 07:07 PM
  3. Tandem fuel pump replacement
    By wizbongre in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-06-2010, 02:47 PM
  4. A4 tdi fuel pump replacement
    By simyboye in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-06-2008, 05:03 PM
  5. fuel pump replacement ?
    By white.akita in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-05-2008, 08:25 PM
