Thread: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    1840 Post(s)
    Yes, those that don't use the Devils own urine...
  2. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    And what are the thoughts on the 1.4 TSI engine?
  3. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    1840 Post(s)
    I am sorry, this is a public forum and foul language is not allowed… all I can say is they are 54i7…
  4. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    Well, the time has come to depart from the ****** VW brand, the Passat is now up for sale as she doesn't trust it any longer. After the T5.1 let me down in exactly the same way a few years ago I've never looked back from my Mercedes Vito, it's bulletproof. Thanks to all on the forums over the years, some great info and help out there!
  5. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    Sep 2009
    Oxford
    Starts occasionally, ticks over badly and won't rev and is ready for breaking tbh! Help peeps?!Pressure on the rail is 200+ bar after having new pump, reconditioned injectors by Diesel Bob, new high pressure fuel pump. Started, but won't run well, lumpy as **** but won't rev/boost and cuts out! Possible timing?? Help please before i break it for parts?
  6. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    1840 Post(s)
    Do you have VCDS?
  7. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    #17
    Sep 2009
    Oxford
    Yes I do
  8. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    #18
    1840 Post(s)
    Have you checked the IMA numbers on the injectors with those registered. I don't know if recon injectors keep this value, I know the new range of Bosch recons have a new number applied. The valve timing could be wrong but if you use the right tools you have to try pretty hard to get it wrong. No fault codes obviously?
  9. Re: 2.0TDi Not Firing After Breakdown and Fuel Pump Replacement
    #19
    Sep 2009
    Oxford
    HI Crasher and thinks for your help on this one. So, huge steps in the right direction! Turns out the reconditioned injectors were supplied with the wrong copper seals and therefore wouldn't maintain a seal when running. A trip to TPS and the damn thing spun up first time and hasn't missed a beat since! Go figure! Hopefully I can park this one for now and the shed keeps going for the foreseeable future. Thanks again for your time, J
    1 1 0
  1. Question 2009 Mk6 2.0tdi fuel pump??
    By Mickyroo in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2020, 10:33 AM
  2. Question TDI Fuel Pump Failure and Replacement
    By pravens in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-01-2013, 07:07 PM
  3. Tandem fuel pump replacement
    By wizbongre in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-06-2010, 02:47 PM
  4. A4 tdi fuel pump replacement
    By simyboye in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-06-2008, 05:03 PM
  5. fuel pump replacement ?
    By white.akita in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-05-2008, 08:25 PM
