Thread: 55 plate touran ignition or steering lock problems?
Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
  1. Re: 55 plate touran ignition or steering lock problems?
    #41
    May 2010
    edinburgh
    I misunderstood at the beginning. I thought if I took the key out of the barrel when the barrel was removed, it would cease to operate, that is why I left the key in.
    I understand now, too late unfortunately. Any suggestions for removing steering lock? I will get it out, but would welcome any method they causes the least damage
  2. Re: 55 plate touran ignition or steering lock problems?
    #42
    1841 Post(s)
    You have to drill the tops off the two shear bolts.
  3. Re: 55 plate touran ignition or steering lock problems?
    #43
    May 2010
    edinburgh
    Yup, I have done that, the steering lock itself was jammed on, but managed to dislodge it by drilling through the side of the lock body. So all good, everything off and ready to rebuild. Appreciate the help 😊
  4. Re: 55 plate touran ignition or steering lock problems?
    #44
    May 2010
    edinburgh
    I forgot to post after saga over...managed to fix it so a big thank you to all for suggestions and advice 😊
  1. Steering control module and ignition lock problem
    By kimlk in forum Touran - Sharan - Caravelle
    Last Post: 29-04-2019, 07:45 PM
  2. Please Help Ignition Lock Defective - contact workshop - no ignition, car is a brick
    By paceman in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-04-2019, 10:24 PM
  3. Question "Ignition Lock Failure" after Led License plate coding...
    By minaetdave in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-04-2017, 08:18 PM
  4. Question 56 Plate Touran door lock issue please advise
    By vrooze in forum Touran - Sharan - Caravelle
    Last Post: 29-08-2016, 12:49 AM
  5. Attention steering lock/ column problems
    By corro in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-04-2011, 11:19 PM
