Thread: Passat coolant issue
Results 1 to 9 of 9
  1. Passat coolant issue
    Jun 2021
    Glasgow
    My Passat b5.5 coolant needs to be topped up every morning I changed expansion tank and still having the same issues
    There's no puddles of coolant/water just always low in the morning
    Tried k seal and radweld with no help
    Pipe work under neath the coolant expansion tank has got like a brown coating over the pipes
  2. Re: Passat coolant issue
    1836 Post(s)
    When used at a constant high load, such as on a motorway, the PD TDI engine such as the AWX and AVF is prone to blowing coolant out of the expansion tank due to head gasket failure.
  3. Re: Passat coolant issue
    Jun 2021
    Glasgow
  4. Re: Passat coolant issue
    1836 Post(s)
    I can’t read it, my iPad sends it all over the right of the screen and up into space…
  5. Re: Passat coolant issue
    Jun 2021
    Glasgow
    You got WhatsApp or telegram?
  6. Re: Passat coolant issue
    1836 Post(s)
    I can see the reg now and on my system it shows as being an AVF, if these only blow coolant out of the tank under load such as motorway use, then in my experience it is always head gasket failure.
  7. Re: Passat coolant issue
    Mar 2021
    GB
    I had the same issue for ages, though it was head gasket but confirmed it wasn't with a sniff test. Check the coolant sensor on the back of the engine block that can weep. Mine was a leaking radiator Rad weld never fixed it you'll have to replace it. It was leaking both ends but couldn't be seen until it was removed. I also found a small leak coming from the sensor built in to the underside of the expansion tank.
    Hope this helps.
    Sent from my SM-G980F using Tapatalk
  8. Re: Passat coolant issue
    1836 Post(s)
    Not in your case but with a PD TDI the sniff test is not a reliable indicator of head gasket failure as it only shows up under constant hard load which is difficult to replicate in the workshop
  9. Re: Passat coolant issue
    Mar 2021
    GB
    Not in your case but with a PD TDI the sniff test is not a reliable indicator of head gasket failure as it only shows up under consthard load which is difficult to replicate in the workshop
    That's handy to know cheers, what would be the way, pressure test?
  1. strange coolant issue
    By bear1987 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2016, 12:05 PM
  2. Audi A3 coolant issue
    By dave192 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-03-2014, 11:31 PM
  3. Coolant Temp Issue
    By jdw88rm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-02-2014, 10:33 AM
  4. Please Help Newbie needs help - coolant fan issue
    By gnat in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-06-2011, 11:01 AM
  5. Coolant issue
    By timbowheelnut in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-04-2010, 12:02 PM
