Thread: A troublesome vibration conundrum
  1. A troublesome vibration conundrum
    Aug 2010
    Rayleigh
    In need of assistance and would appreciate some helpful suggestions. I own a pre-facelift ultra s-tronic avant that has covered 95k miles relatively faultlessly. Audi replaced the front pads and discs in February this year and all seemed good until April time when I encountered the following:
    1. Slight judder when braking hard,
    2. Vibration through the front of the car when travelling at 60 and above. The vibration worsens with speed and can still be felt although dampened when coming off the power.
    To add, not sure if this is related but the gear changes appear clunkier at lower speeds.
    I donít think itís wheel balancing issue as I had the fronts checked.
    Any ideas on what else this might be?
  2. Re: A troublesome vibration conundrum
    Aug 2009
    cheshire
    6 Post(s)
    88 Post(s)
    i would possibly look at either driveshaft imbalance and the flywheel. A good gearbox specialist might be able to help with the flywheel diagnosis. Also try a local indy.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill plates,Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  3. Re: A troublesome vibration conundrum
    62 Post(s)
    1177 Post(s)
    Could be warped discs caused by warped hubs, a failing wheel bearing, a bent wheel or faulty tyre(s). What make re the tyres?
    A petition has been started to allow the use of synthetic fuels when they become available, this may allow the continued sale of ICE vehicles post 2030 and the use of classic vehicles well into the futureÖ Their use may even be able to rival electric vehicles given the chance. Please sign this petition IF you feel the infernal combustion has a future if sustainable fuels are made available
    https://petition.parliament.uk/petitions/588774
  4. Re: A troublesome vibration conundrum
    Aug 2010
    Rayleigh
    Hi Crasher,
    They are Goodyear eagles F1
  5. Re: A troublesome vibration conundrum
    62 Post(s)
    1177 Post(s)
    If they are young ish they should not be the problem, I would have the wheels checked for runout and the discs too.
  6. Re: A troublesome vibration conundrum
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    12 Post(s)
    I'm with Crasher on that one. Until recently I only had Audi genuine discs/pads on both my A4 and the A6, but I had the same thing happen on both the A4 and the A6 - the two halves of the brake disk separated. It was enough to have some freewheeling between the two halves and they would "bind" as they hit each other while rotating creating a sensation not unlike vibration and an noise not unlike a wheel-bearing on the way out. Put your foot on the brakes and if you were lucky they bit flat and you braked normally, if not there was a fair bit of noise and judder.
    Interestingly, front passenger side on both cars was the one that failed....not that they are handed....so something weird, or I'm a very selective vandal
    D.
  1. Cam belt conundrum
    By Chewmyr00t in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-03-2017, 01:42 AM
  2. 2.0TFSI vs S4 conundrum
    By gr4z in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-11-2013, 10:40 PM
  3. Small Conundrum
    By nwells in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-07-2009, 11:41 PM
  4. Are all A3 1.6s troublesome?
    By colina3 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 29-02-2008, 04:58 PM
  5. mathematical conundrum
    Last Post: 26-10-2007, 01:59 PM
