Thread: Brake pedal switch
  1. Brake pedal switch
    Jan 2021
    Skien Norway
    Hi, I have a wierd problem, my abs and esp lights are on, have scaned with vcds and this code is coming up P0571 - 35-10 - Implausible Signal - Intermittent,i have changed the the switch but still same problem. I had the same issiue last year when i bought the car, but it went away when the weather got colder, but now its warmer agian its back. The last owner changed to led tail lights, can this make this problem?
  2. Re: Brake pedal switch
    1840 Post(s)
    Yes, the reduced current draw of LED's can cause this problem as can a poorly fitted or cheap aftermarket switch, is the switch genuine and did you fit it pedal up or down?
  3. Re: Brake pedal switch
    Jan 2021
    Skien Norway
    Oem switch and pushed down the pedal. I think i found the problem, it was with the led lights and a very bad wiring job.
  4. Re: Brake pedal switch
    1840 Post(s)
    The switch, if the OE design, must be fitted with the pedal up in the rest position as if installed pedal down, as you release the pedal it destroys the switch.
  1. Please Help Brake pedal spongy, hissing when depressing pedal
    By The Norwegian in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2016, 11:09 PM
  2. Replies: 6
    Last Post: 27-09-2011, 07:49 PM
  3. Brake pedal switch
    By gazz1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-06-2010, 06:30 AM
  4. brake pedal switch issue
    By gordnigolf in forum Golf MK3 - 1993 - 1999
    Last Post: 09-12-2008, 12:10 PM
  5. Question VW Golf GT TDI 115bhp Brake Pedal Switch
    By kabz in forum Golf MK4 - 1999 - 2004
    Last Post: 03-10-2008, 05:06 PM
