Thread: 1.2 SE Suspension
  1. 1.2 SE Suspension
    Apr 2018
    Swindon
    I have a 90K 2005 SE 9n3 1.2 3cyl
    the suspension is great - it soaks up rough roads and pot holes as good as my 2019 Passat!
    but other times (cornering) if feels too soft and wallowy
    I was thinking about replacing the rear shocks and Springs - but wondered if there are any HD springs I can use on the back?
    I don't want to lower it.
    Thoughts?
  2. Re: 1.2 SE Suspension
    1836 Post(s)
    You could use the factory sports springs, many of which are available from Suplex for much less than genuine. Mrs Crasher has a 2006 Polo 9N3 GTI and the ride plus roll stiffness of the factory system is bordering on being like an aftermarket coil over kit, much stiffer and jittery than even my Octavia VRS which is FULLY Powerflexed with Koni Active dampers, Eibach springs and a thicker front anti roll bar. If you message me the REG and I work out some ideas based on the factory PR codes.
  3. Re: 1.2 SE Suspension
    Apr 2018
    Swindon
    Many thanks msg on its way
  4. Re: 1.2 SE Suspension
    1836 Post(s)
    I would fit the stiffer 20mm front anti roll bar 6Q0 411 305 AN which is £90.28 retail from a VW dealer but to stiffen the rear is a lot more involved as you have to fit the GTI rear axle 6Q0 500 051 BC which is £701.48 and quite involved to install. In addition, an ST spring and damper kit with Powerflex bushes in the front wishbones.
  1. Please Help Front suspension spring and suspension arms
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-06-2018, 02:16 PM
  2. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  3. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  4. S Line suspension vs Sports Suspension - Retro fit
    By scoobmw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2010, 09:23 AM
  5. Mechanical differences between Sport suspension and ordinary suspension
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-06-2010, 05:03 PM
