Thread: Passat b7 01314 01325 fault code
Results 1 to 10 of 20
  1. Passat b7 01314 01325 fault code
    Jun 2021
    Great Britain
    Hi guys
    I have a Passat B7 2012 2.0 TDI 114.000 miles.
    I’m experiencing that randomly it won’t start. I have tyre pressure monitor fault parking brake error and ESC fault on the dashboard. I take the key out trying again and it’s working. The engine never cuts off and drives well on every gear.
    Sometimes disappears for days then it comes back and I’m struggling starting it up.
    Battery is new and tested, ECU is dry.
    I have a chinese head unit installed instead of the original one.
    On the scanner theese 2 codes came on
    01314-ECU-no signal and 01325- tyre pressure monitor system.
    Weird enough this car never had tyre pressure monitoring system.
    Not sure if anyone experienced the same issue if you guys have any ideas please share that with me.
    Thanks in advance.
    Have a great weekend
  2. Re: Passat b7 01314 01325 fault code
    108 Post(s)
    1816 Post(s)
    Is the new battery an AGM type?
  3. Re: Passat b7 01314 01325 fault code
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    From Ross-tech :-
    01314 - Engine Control Module
    01314 - Engine Control Module: No Communications
    Possible Causes
    • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
    • Fault(s) stored in Engine Control Module
    • Engine Control Module recently flashed or re-mapped
    Possible Solutions
    • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
    • Check Measuring Value Blocks (MVB)
      • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    Special Notes
    • When found in the (1K) chassis with 2.5L gas engine using a MAF (G70) sensor, check the T121/62 (Red/Black) traced power wire to the ECM. If power is missing or a voltage drop is present that wire may be damaged anywhere between 6" and 18" from the connector itself. This will result in no communication in addition to a no-start.
    01314 - Engine Control Module: Check DTC Memory
    Possible Causes
    Possible Solutions
    • Check Engine Control Module for Fault Codes
    Special Notes
    • Engine Control Module stored a Code which influences other Control Modules Functionality.
    • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
    I would get a VCDS scan done first & see what that throws up.
  4. Re: Passat b7 01314 01325 fault code
    Jun 2021
    Great Britain
    Yes it is
  5. Re: Passat b7 01314 01325 fault code
    Jun 2021
    Great Britain
    Thnaks
  6. Re: Passat b7 01314 01325 fault code
    Jun 2021
    Great Britain
    @Crasher yes battery is AGM type checked by the mechanic and all good
  7. Re: Passat b7 01314 01325 fault code
    Jun 2021
    Great Britain
    @philipharmes the guys from the garage after the diagnosis said the 01314 code is appearing in connection with data bus, power steering, brake button, central electrics, brake electronics.
    Not sure if I have got this right but this is what they wrote down.
    The car still starts and drives only sometimes this happens when is taking about 4-5 attempt to try till fires up.
    I will attach a video might help.
    Thank you for your help.
  8. Re: Passat b7 01314 01325 fault code
    Jun 2021
    Great Britain
  9. Re: Passat b7 01314 01325 fault code
    108 Post(s)
    1816 Post(s)
    In which controller do you get 01314?
  10. Re: Passat b7 01314 01325 fault code
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If you watch your video carefully you will see that the engine light doesn't illuminate the first few times you operate the ignition.
    The last time you switch on the ignition it illuminates straight away & the car starts.
    Without looking at a wiring diagram, I am assuming the engine light is driven from the ECU.
    So am guessing that the ECU isn't being powered until the last time you switch on the ignition.
    Have a look at these youtube videos where you can see the ECU is powered up by the 100 relay in the engine bay fuse box.
    VW Golf 5 1.9TDI ECU relay power for engine control module - YouTube
    VW / AUDI relay 100 test and measure 7MO 951 253A /secondary fuel pump relay?/ - YouTube
    I'm guessing it could be the relay itself or wiring associated with it.
    If you are handy with a test meter it should help to get to the bottom of the problem.
    Best of luck.
  1. Return of the 01314 code with crank but no start
    By Lincs-sline in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 07-03-2021, 06:47 PM
  2. 01314 FAULT CODE - APOLOGIES ORIGINALLY POSTED IN mk5
    By 1611AZTEC in forum Golf MK4 - 1999 - 2004
    Last Post: 05-02-2021, 07:38 PM
  3. Fault codes 01314 AND 00526
    By 1611AZTEC in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2021, 07:09 PM
  4. 01314 - engine control module 49-10 - no communications Fault code
    By kizzy666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2014, 11:59 AM
  5. Non Starter - VAG Code 01314
    By hapz1 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2010, 10:53 PM
