Thread: GPS signal loss inside car
Results 1 to 10 of 17
  1. GPS signal loss inside car
    Feb 2016
    London
    13 Post(s)
    Bit of a random one this. Keep getting GPS signal loss on my Android phones ( S7 and latterly S9 Samsung) while inside the car. Tried all the fixes from within the phone but the only way to get the signal back is to stop the car, get out and move away from it. The AMI sat nav actually works but shows 0 satellites so not sure how that's possible. I'd hazard a guess that some onboard device is interfering with the signal as I can have the phone on the top of the dash or hold it next to the open window and my GPS status app shows zero satellites. Occasionally it will look like it's getting one or two but they quickly disappear. Outside the car it will lock on dozens of satellites in a few seconds every time like it should. Either it's a new car or a new phone but the later may not change anything.......
    Anybody ever come across anything like this? The only info I can get from fruitless internet searching is that the signal is being jammed.
    2011 A6 Allroad 3.0TDI
  2. Re: GPS signal loss inside car
    1840 Post(s)
    Does your car have a heated windscreen?
  3. Re: GPS signal loss inside car
    Feb 2016
    London
    13 Post(s)
    No
  4. Re: GPS signal loss inside car
    1840 Post(s)
    I don't know then as I only have a proper phone with ios...
  5. Re: GPS signal loss inside car
    Jul 2008
    Lisburn
    15 Post(s)
    its only a matter of time before your car is not a supported accessory - IOS no longer works with the FL2..
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  6. Re: GPS signal loss inside car
    1840 Post(s)
    My car is so old it thinks an apple is a fruit... but the head unit is bang up to date DAB+ iOS etc and I don't have to change the car to upgrade it
  7. Re: GPS signal loss inside car
    Jul 2008
    Lisburn
    15 Post(s)
    LOL. We just let go of the FL2 -wife is an apple fan - and she now has a F-Pace.
    One of the threads over there is al about EZ-pass, garage door openers, and radar detectors not working.
    The answer was that the heat/solar reflective layer in the windows block the signals, not the heated screen. All jags have 2 small squares without the reflective layer just behind and either side of the rear view mirror to allow fitment of such devices.
    The jag comes with its own WiFi, i wonder if this is part of the reason?
    Stewart
  8. Re: GPS signal loss inside car
    Feb 2016
    London
    13 Post(s)
    Quote Originally Posted by swwalker View Post
    Even with the window down and the phone held outside it's won't connect. Just reactivated an older phone to keep in the car so I can check if it's the phone or car next time it happens.
  9. Re: GPS signal loss inside car
    1840 Post(s)
    Is it the same with the ignition on and off?
  10. Re: GPS signal loss inside car
    Feb 2016
    London
    13 Post(s)
    The last time it happened I sat with the ignition off and the key out with the phone next to an open window and the GPS only locked when I actually got out of the car and walked away from it.
  1. Heated Rear Screen causes loss of DAB signal
    By N16E in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-12-2014, 05:03 PM
  2. Radio Signal loss linked to Headlights
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2010, 05:34 PM
  3. Replies: 1
    Last Post: 19-08-2009, 10:45 PM
  4. Caravelle Radio Signal Loss
    By Ree in forum Touran - Sharan - Caravelle
    Last Post: 05-05-2009, 01:34 PM
  5. Loss of radio signal on 2004 A4 Cab ?
    By peteadr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2008, 05:50 PM
