Thread: Golf GT PD170 (BMN) injectors values & timing question.
  1. Golf GT PD170 (BMN) injectors values & timing question.
    May 2021
    Norfolk
    Hi, good evening everyone just got our golf gt 2.0 tdi back together after rocker arm failure 😞 resulted in 1 new intake valve all new head bolts & gasket etc, the vehicle is smoking on idle & smells very strong of fuel injector's values I think they look okay but I might be wrong? Iíve set the torsion value 0.0 fuel consumption 0.6 Iíll attach a picture of them below, vehicle still as a DPF, believe the egr is faulty due to it not being able to do an adaption values are over 459mg/## but I have to fault codes for it any help would be much appreciated thanks
  2. Re: Golf GT PD170 (BMN) injectors values & timing question.
    62 Post(s)
    1177 Post(s)
    I can’t see those values but BMN injectors are notorious trouble, I can tell a BMN from a hundred feet away by the stench.
    A petition has been started to allow the use of synthetic fuels when they become available, this may allow the continued sale of ICE vehicles post 2030 and the use of classic vehicles well into the futureÖ Their use may even be able to rival electric vehicles given the chance. Please sign this petition IF you feel the infernal combustion has a future if sustainable fuels are made available
    https://petition.parliament.uk/petitions/588774
  1. golf mk5 2.0 sdi timing belt question??
    By c2lby in forum Golf MK5 - 2004 - 2009
    Last Post: 18-09-2014, 10:55 AM
  2. Timing Belt Change - 2.0 TDI PD 170 (& Injectors Q)
    By Brydo666 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-03-2012, 11:50 PM
  3. Injectors values VCDS
    By klitoni in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2012, 06:14 PM
  4. Question about BKP injectors
    By goldenwonder in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2011, 02:11 PM
  5. Golf - Poor resale values
    By cs2009 in forum Golf MK6 - 2009 - 2013
    Last Post: 15-02-2011, 12:34 PM
