Thread: 2015 BiTDI Oil Change
Results 1 to 10 of 15
  1. Question 2015 BiTDI Oil Change
    Apr 2014
    London, UK
    12 Post(s)
    I recently purchased a second hand A7 2015 BiTDI (320PS) and according to the car it requires an oil change soon.
    I was thinking I would do it myself. A friend of mine has jacks, so we should easily be able to drain the existing oil.
    However, I have no idea what oil I should get and if I need to change the oil filter as well? Any advice would be greatly appreciated
  2. Re: 2015 BiTDI Oil Change
    May 2012
    Manchester
    9 Post(s)
    Hi mate,
    definitely need to change the oil filter. You can get em cheap from Euro Car Parts. I suggest changing the air filter to. For the oil you need a 5w30 fully synthetic one but vag approved. I tend to use the castrol edge 5w30 but i think there are a few other ones you can use too
    if its just the oil change its pretty standard it you know what you’re doing. Undo the sump on the bottom and drain. Might be worth replacing the sump plug too
    2008 Audi A6 C6 S-Line Saloon, 2.0 Diesel with Multitronic Gearbox. BRE engine code and remapped to 170BHP (Stock was 140) Has 85k on the clock
  3. Re: 2015 BiTDI Oil Change
    131 Post(s)
    1976 Post(s)
    Having the car at an angle means a significant amount of oil runs to the back of the sump, asking if you should change the filter makes me think you should not be doing the job.
    0 2 0
  4. Re: 2015 BiTDI Oil Change
    May 2012
    Everywhere
    308 Post(s)
    Do it all from the top by buying a 9L extractor from the bay .
    Mann are oem but the build quality is better on Hengst and Bosch filters .
    Oil !
    507.00 and it doesn't have to be approved .
  5. Re: 2015 BiTDI Oil Change
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Its an expensive car to fix if you get it wrong, so take it to an Audi specialist. You will also have to remove and replace the engine floor panel which will be quite tricky to do using axle stands.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  6. Re: 2015 BiTDI Oil Change
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Oil should be VW approved. A lot of oil manufacturers say their oils meet VW specs but that is their opinion and is not supported by the VW tests. If their oil does meet VW specs why don't they get it VW tested and approved ?
    Skoda Octavia II SE 1.9PD TDI
  7. Re: 2015 BiTDI Oil Change
    May 2012
    Everywhere
    308 Post(s)
    He he , tried and long term tested this one...
    Approval is a marketing decision so that the oil may be sold at a higher price but the producer / blender might not be high volume or wishes to supply high volume to another market .
    Have you ever heard of the American oil analysis company...
  8. Re: 2015 BiTDI Oil Change
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    And how much is an oil change from a dealer or independent?
  9. Re: 2015 BiTDI Oil Change
    Apr 2014
    London, UK
    12 Post(s)
    I decided to pass on trying to do this myself. Got a booking at Kwik-Fit this Saturday
  10. Re: 2015 BiTDI Oil Change
    May 2012
    Everywhere
    308 Post(s)
    Quick-Quid , might aswel let a 5 year old do it !
  1. 2015 euro A6 3.0 biTdi EGR valve location
    By javyb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 20-11-2023, 01:25 PM
  2. Passat 2015 high beam bulb change
    By hudson0804 in forum Passat - B8 Forum - 2015 -
    Last Post: 23-09-2018, 02:38 PM
  3. Replies: 1
    Last Post: 26-03-2018, 09:09 AM
  4. Question A6 BiTDI (2015) - First Service
    By hshah in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-04-2017, 11:49 AM
  5. A6 BiTdi going, decided to try petrol for a bit of a change
    By Chesterfield313 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-12-2016, 09:05 PM
