Thread: 2.0TDi CFFB Normal Oil Temperature Range?
  1. 2.0TDi CFFB Normal Oil Temperature Range?
    Jan 2013
    N/A
    Hello fellow B7 owners.
    I just drove back about 35miles (20miles on motorway) with our new Estate 2.0TDi CFFB. Sounds good overall and we're happy with it.
    I noticed one thing on the multifunction display (MFD); there's oil temperature digital display (no idea where in the engine the oil temperature is taken). On the motorway, I was drove at 70mph on 3rd gear to trying out Italian tune-up and wondered if DPF regeneration would kick-in (it didn't). The oil temperature swiftly went up from 90C to nearly 110C within 5min or so. I changed gear to 6th at 108C as I was not comfortable with oil getting hotter than that. Upon changing up to 6th gear, it went back down swiftly to 100-103C. Coming off the motorway and on an A-road (50mph, 5-6th gears) the oil temperature fluctuated between 97-103C.
    I always assumed that both oil and coolant sits at 90C. The analogue coolant temperature gauge was solid at 90C the whole journey.
    That oil temperature range should we be seeing in normal driving and at what temperature level should I be worried?
    Happy motoring!
    '11 VW B7 Passat Estate 2.0TDi CFFB (Current)
    '98 VW T4 Transporter 2.5TDi ACV (Previous)
    '99 Audi B5 A4 Avant 1.9TDi AFN (Previous)
  2. Re: 2.0TDi CFFB Normal Oil Temperature Range?
    Jan 2016
    Winchester Hants
    29 Post(s)
    Mine runs between 90 and 96, but I rarely take the engine above 2k rpm for long periods.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  3. Re: 2.0TDi CFFB Normal Oil Temperature Range?
    Jan 2013
    N/A
    Quote Originally Posted by UMEL View Post
    Thanks UMEL, it's helpful to know the oil temperature range under 2,000rpm. The reason why I was going ver high on rev was to see if it triggers DPF regeneration. This is the first vehicle with DPF so I just assumed that DPF regeneration would kick in if the exhaust gets hot enough. Have yours ever triggered DPF regeneration if you drive mostly under 2,000rpm?
    Happy motoring!
  4. Re: 2.0TDi CFFB Normal Oil Temperature Range?
    Jan 2016
    Winchester Hants
    29 Post(s)
    It does regen but rarely. I'm not sure if it's after a longish run (30 miles at say 60mph) or just poodling around home.
  1. P0183 G81 FTS problem on a CFFB 2.0Tdi engine
    By shabazmo in forum Golf MK6 - 2009 - 2013
    Last Post: 26-11-2020, 11:33 AM
  2. Question Coolant temperature gauge dips after 10min drive and returns to normal
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-05-2015, 10:53 AM
  3. Whats The Normal Running Temperature on 1.9TDI?
    By slee02 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-08-2012, 12:06 PM
  4. 2.0TDI normal levels of smoke??
    By 427scr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-07-2010, 01:30 PM
  5. Normal coolant temperature
    By JonG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2010, 06:54 PM
