Thread: Clunky start up and other noises
  1. Clunky start up and other noises
    Feb 2021
    GB
    Hi guys hope alls well, new to the audi scene, got my partner a 2.0tfsi quattro sportback 2011 80k mileage, timings been done by previous owner but there's an oil leak coming from the timing case so Iv ordered the top & bottom timing covers from tps and its getting done this weekend, is there anything to look out for while it's open etc
    1st annoying noise is
    Sometimes on start up it clonks/taps for about 2 seconds and then it goes
    2nd noise is the gearbox
    When you put it into drive or reverse from Park it makes a little clunk noise coming from the rear, but this clunk gets louder when your driving it and it downshifts from 3 to 2 etc (in sport mode only) I hope the gearbox aint on its way out
    3rd little annoying noise
    Everytime you lift your foot off the gas (no matter how much you've pressed it down) it makes a little tinny/springy type rattle noise coming from under the engine which lasts around 2 seconds
    Your help will be really appreciated as we've looked around and can't pin point any of it
    Thank you in advance and i hope your all having a good day
    Sent from my SM-N976B using Tapatalk
  2. Re: Clunky start up and other noises
    Feb 2021
    GB
    *Bump
    Any help would be appreciated guys thanks
  3. Re: Clunky start up and other noises
    1840 Post(s)
    The recent chain work and start up rattle are worrying, the rest needs an experienced ear to have a listen.
  4. Re: Clunky start up and other noises
    Feb 2021
    GB
    Got both top and bottom covers new from tps hopefully open it up next Saturday and see inside
  5. Re: Clunky start up and other noises
    1840 Post(s)
    Replacing the bottom cover opens a can of worms where the timing can slip if the correct tools are not used and the centre bolt of the pulley MUST be replaced.
  6. Re: Clunky start up and other noises
    Feb 2021
    GB
    my mates a pro lol he's a vag specialist, we need to replace it as its leaking from the cover, probably where they pryed it open and bent it etc
    Once it's opened then we can hopefully check what's been done
  7. Re: Clunky start up and other noises
    Feb 2021
    GB
    I forgot to post an update
    Everything was ok upon opening it up so we just put on the new cases (bolts etc) which has stopped the small oil leak it had, now to find the causes of the noises i was told the start up rattle (intermittent) could be the flywheel?
  1. Clunky Noise.
    By snowy0230 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2010, 03:33 PM
  2. Please Help HOT WEATHER - car wont start (no noises at all)
    By hornetcarp in forum Golf MK3 - 1993 - 1999
    Last Post: 23-06-2009, 09:52 PM
  3. Clunky Bora!
    By craig.scoobsvil in forum New Member Introductions
    Last Post: 06-02-2009, 11:59 PM
  4. Anyone got a clunky seat?
    By AndyH123 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-07-2008, 01:53 PM
  5. Clunky gearbox
    By gregpaterson in forum Audi A4 - Archive Topics
    Last Post: 11-03-2007, 09:44 AM
