Thread: N75 Problem perhaps
  1. N75 Problem perhaps
    Jun 2021
    Birmingham England
    Hi All
    New member here with a mk4 Golf 1.9PDI 130 engine. 155k miles but was running perfectly until today, when I reached about 60mph (high revs) I suddenly lost power, no blacks smoke and engine seems to sound ok except for low power.....Pulled over turned engine off and on and it was ok again.
    Done a bit of reading up and wonder if it could be the N75 valve? Don't want to take it to garage for them to try and tell me it needs a new turbo so wondered if there is a way I can diagnose it myself before looking to get it fixed?
    Any help appreciated....
  2. Re: N75 Problem perhaps
    Jun 2021
    3rd rock frm sun
    I have a pd130 in an A3 03 plate,258K, had this prob yrs ago sounds like you are describing it going into limp mode, due to taking longer than expected to reach required boost, I tracked fault down to intercooler leak, stone chip/crack etc, and or a pipe leaking. It dont take much for them to sence that its taking too long to reach boost -thus limp mode, an a quick off on of key cures the prob . N75 usualy bullet proof, Ive never had one packup over last tens of yrs ! Let us kno how you get on Thank.
  3. Re: N75 Problem perhaps
    Jun 2021
    Birmingham England
    Thanks for that oilburnner, sounds postive and hopefully a relatively cheap fix. I love my golf (sometimes wonder why!) so will be happy to throw a little money at it to sort it
  4. Re: N75 Problem perhaps
    1840 Post(s)
    Have a fault code read done, the likely result is under or over boost codes and both have very different causes, guessing is a waste of time and usually money.
  5. Re: N75 Problem perhaps
    Jun 2021
    3rd rock frm sun
    I should have said - I did get a code read with vagcom, and it telling me under boost. But I did trace the fault down to leaking intercooler as I seen a weep of oil from it. But as Crasher says a code read is the first step realy !
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
