Thread: Help with a few issues
  1. Help with a few issues
    Dec 2013
    Liverpool
    10 Post(s)
    Did a scan on my mates 2010 CC today as he has been having issues with the car not starting once it has warmed up.
    Also his SAT NAV Language is in German and it wont change to U.K. Is there a software update that could fix the SAT NAV if so where can I download it?
    Here is the scan results.
    Tuesday,08,June,2021,15:53:19:20402
    VCDS Version: 21.3.0.0 (x64)
    Data version: 20210226 DS325.0
    Ross-Tech: Home
    VIN: WVWZZZ3CZAE551546 License Plate:
    Mileage: 155120km-96387mi Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 25 37 42 44 46 4F 52 53 56
    62 69 72
    VIN: WVWZZZ3CZAE551546 Mileage: 155120km-96387miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: Not registered 0011
    16-Steering wheel -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 QG HW: 03L 907 309
    Component: R4 2,0L EDC 0000AG 6212
    Revision: 13H03--- Serial number: VWZCZ000000000
    Coding: 0000078
    Shop #: WSC 80093 222 71269
    VCID: 7AFBDE963590EB5B8D-802E
    6 Faults Found:
    008198 - Intake Manifold Flap; Bank 1
    P2006 - 000 - Stuck Closed - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 255
    Mileage: 154729 km
    Time Indication: 0
    Date: 2015.10.04
    Time: 00:30:34
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Load: 100.0 %
    Lambda: 52.1 %
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 43.2°C
    001642 - Glow Plug Cylinder 1
    P066A - 000 - Short to Ground
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 154730 km
    Time Indication: 0
    Date: 2015.10.09
    Time: 00:25:52
    Freeze Frame:
    RPM: 1564 /min
    Speed: 32.0 km/h
    Voltage: 14.21 V
    Temperature: 17.1°C
    Bin. Bits: 10110000
    Time: 0.36 s
    Temperature: 14.4°C
    000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 - 000 - Incorrect Correlation - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 154775 km
    Time Indication: 0
    Date: 2015.10.19
    Time: 13:27:40
    Freeze Frame:
    RPM: 989 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Idle Stabilization: -2.7°KW
    RPM: 547 /min
    (no units): 33.0
    008196 - Intake Manifold Flap; Bank 1
    P2004 - 000 - Stuck Open - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 9
    Reset counter: 255
    Mileage: 154729 km
    Time Indication: 0
    Date: 2015.10.04
    Time: 23:00:05
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Load: 100.0 %
    Lambda: 89.2 %
    Temperature: 36.9°C
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 154729 km
    Time Indication: 0
    Date: 2015.10.04
    Time: 23:01:11
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Lambda: 11.0 %
    Lambda: 4.7 %
    Voltage: 0.380 V
    Bin. Bits: 10000001
    001674 - ECM Power Relay Load Circuit
    P068A - 000 - Opens Too Early - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 0.00 V
    Hex Value: 0xFF00
    Bin. Bits: 00000000
    Temperature: -90.0°C
    Readiness: 0 1 0 0 0
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 052 S HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2108
    Revision: 51112 Serial number: 00001002180978
    Coding: 0000020
    Shop #: WSC 05311 000 00000
    VCID: 2447C0EEE7944DAB87-8070
    No fault code found.
    Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
    Component: J104 C4 440 V2 0015
    Revision: --025--- Serial number: 00000104083954
    Coding: 0003368
    VCID: 62CB86F6BD00039BB5-8036
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
    Component: Climatronic H15 0709
    Revision: 00003001
    Coding: 0000000002
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_Climatronic A01006
    ROD: EV_ClimaAutoBasis_VW46.rod
    VCID: 7EF3D286E1B8C77BB1-802A
    1 Fault Found:
    9481200 - Refrigerant Pressure
    B10AB F0 [009] - Too Low
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 154729 km
    Date: 2021.05.13
    Time: 23:10:52
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000003682881
    Coding: E1808F8B00041A0047970F00170000000008FB475C40017C17 4000000000
    Shop #: WSC 05124 000 00000
    VCID: 336533B2527ADA130E-8066
    Subsystem 1 - Part No: 3C8 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 150210 022 0613
    Coding: 00046997
    Shop #: WSC 05124
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 030310 054 0403
    Coding: 00209133
    Shop #: WSC 05124
    Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
    Part No SW: 3C8 919 475 A HW: 3C8 919 475
    Component: PARKHILFE 8K H07 0009
    Revision: -------- Serial number: 08741006405587
    Coding: 110101
    Shop #: WSC 01130 210 66681
    VCID: 326B36B66D60D31B05-8066
    Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
    Part No SW: 3C0 907 376 A HW: 3C0 907 376
    Component: DAEMPFUNGS-SG H07 0070
    Revision: 00000000 Serial number: 02031003950002
    Coding: 010180
    Shop #: WSC 05314 000 00000
    VCID: 275DD7E256A2A6B3A2-8072
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
    Component: J234__305 VW10 HI 1916
    Revision: 20013000 Serial number: 003E2P3YWN9G
    Coding: 0012341
    VCID: 4487606E07D46DABA7-8010
    Subsystem 1 - Serial number: 6332MTS622080420
    Subsystem 2 - Serial number: 6342MTS614420400
    Subsystem 3 - Serial number: 6351HTS6A8M186KR
    Subsystem 4 - Serial number: 6361HTS6DES186KJ
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 33
    Reset counter: 165
    Mileage: 154729 km
    Time Indication: 0
    Date: 2015.10.04
    Time: 23:10:52
    Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
    Part No SW: 3C5 953 501 BF HW: 5K0 953 569 S
    Component: LENKS.MODUL 009 0122
    Revision: FF010035 Serial number: 20100222200797
    Coding: 098A070002
    ASAM Dataset: EV_VW360SteerWheelUDS A03002
    ROD: EV_VW360SteerWheelUDS.rod
    VCID: 6ADBEED68D305BDB7D-803E
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-TK6 H06 0022
    Coding: E20000
    2 Faults Found:
    365060 - Controls in Steering Wheel
    U108E 00 [008] - No Communications
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 16
    Reset counter: 164
    Mileage: 154729 km
    Date: 2021.05.13
    Time: 23:11:23
    365080 - Controls in Steering Wheel
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 154732 km
    Date: 2021.05.25
    Time: 00:31:15
    Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
    Part No SW: 3C8 920 970 L HW: 3C8 920 970 L
    Component: KOMBI H03 0305
    Coding: 440F00
    Shop #: WSC 05314 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
    VCID: 35610DAA940EC42320-8060
    Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 N HW: 3C0 907 951
    Component: J533 Gateway H14 0172
    Revision: H14 Serial number: 1021G1030100CF
    Coding: 7DA87F46400203009003
    VCID: 2C5728CE8F4485EB4F-8078
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 49
    Reset counter: 127
    Mileage: 154729 km
    Time Indication: 0
    Date: 2015.10.04
    Time: 23:10:58
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
    Component: IMMO 043 0383
    Revision: 00043000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    Subsystem 1 - Part No: 3C0 905 861 H
    Component: ELV 028 0380
    3C0905861H ELV 028 0380
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 4
    Reset counter: 147
    Mileage: 154731 km
    Time Indication: 0
    Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
    Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
    Component: RNS-MID H06 2680
    Revision: AB001001 Serial number: VWZ6Z7K5063028
    Coding: 04010402040000A000
    Shop #: WSC 05314 123 12345
    VCID: 2E5322C67958F7FB61-807A
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 154731 km
    Time Indication: 0
    Date: 2015.10.14
    Time: 16:41:38
    Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
    Component: TUER-SG FT 002 0308
    Revision: 12101005 Serial number: 0000516056
    Coding: 0012B7
    ASAM Dataset: EV_DCU42BroseDriveSide A03004
    ROD: EV_DCU42BroseDriveSide.rod
    VCID: 7CF7D88EF7A4D56B9F-8028
    Slave Driver:
    Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 004 0401
    Serial number: 00000001323111
    Coding: 000090
    1 Fault Found:
    66048 - Motor for Front Window Regulator
    B11EC 54 [008] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 147
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 209 3001
    Revision: 00H17000
    Shop #: WSC 02069 000 90108
    VCID: 316939BAA866E8037C-8064
    Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 043 0612
    Coding: 01910A0001860E763604941570085FCE107801
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H05 1501
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
    Part No SW: 1K0 907 532 HW: 3C0 907 951
    Component: EZE_2 H14 0172
    Revision: -------- Serial number: 1021G1030100CF
    Coding: 01030100
    VCID: 66C39AE691287FBB59-8032
    Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
    Component: J245/J878 H04 0054
    Serial number: 003400000517
    Coding: 000006
    Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
    Component: TUER-SG BT 002 0308
    Revision: 14101005 Serial number: 0000530585
    Coding: 0012B6
    ASAM Dataset: EV_DCU52BrosePasseSide A03004
    ROD: EV_DCU52BrosePasseSide.rod
    VCID: 79F9C19AF896E04384-802C
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 004 0401
    Serial number: 00000001321327
    Coding: 000090
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
    Component: J540 EPB3 VW-15417 0007
    Revision: 010 Serial number: 00000000187732
    Coding: 0000057
    Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 154731 km
    Time Indication: 0
    Date: 2015.10.14
    Time: 16:41:38
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: ConWys Trailer H07 0100
    Revision: 3A001001 Serial number: 00000132425721
    Coding: 0100000100000000
    Shop #: WSC 00000 000 00000
    VCID: 306F3CBE636CE10B73-8064
    2007 2.7 SE quattro saloon
  2. Re: Help with a few issues
    Dec 2013
    Liverpool
    10 Post(s)
    Any help please??
  3. Re: Help with a few issues
    135 Post(s)
    2026 Post(s)
    I have had a couple of CC’s with this where in the end I came to the conclusion it was water damage inside the ECU but neither customer was prepared to sink £1681.50 into a hunch and who can blame them! The particular ECU in this car 03L 906 022 QG is a known problem under parts bulletin 9-156 but I can’t find it, I will ask TPS tomorrow. Is the battery an AGM type and relatively new? These cars hate non AGM batteries.
  1. Mk5 issues
    By djraw in forum Golf MK5 - 2004 - 2009
    Last Post: 19-05-2016, 02:21 PM
  2. 3TDi starting issues/ dying issues
    By 20vcqdriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2014, 10:01 AM
  3. SD and USB issues.
    By Jwjaudi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-04-2013, 10:37 PM
  4. DPF in 2.0 tdi or just 1.9?and what issues to look out for?
    By Mike McKinstry in forum Golf MK5 - 2004 - 2009
    Last Post: 02-10-2011, 07:18 AM
  5. many issues
    By netdef in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-05-2008, 12:26 PM
