Thread: Oil leak - Timing Chain Cover / Oil Sump
Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
  1. Re: Oil leak - Timing Chain Cover / Oil Sump
    #51
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Got it all back together now.
    Just wanted to check the assembly order of the crank repair sleeve / bushing 03C 198 159A
    There are two 2 discs one flat and one with 4 tangs....
    what’s the order of these when assembling onto the crank?
    pulley
    flat disc
    sleeve (with seal at back)
    disc with 4 tangs (but what orientation? Do they face away or towards you?)
  2. Re: Oil leak - Timing Chain Cover / Oil Sump
    #52
    1841 Post(s)
    Don't forget the retro fit O ring N 909 032 01 or it will leak... you did use one last time; didn't you?
    1 Fastening screw
    2 Crankshaft pulley
    3 diamond-coated disc
    4 Sealing ring for crankshaft
    5 Bearing bush
    6 O-ring
    7 diamond coated disc, the one with the tags clipped over the crankshaft
    Slide the bearing bush onto the crankshaft journal
  3. Re: Oil leak - Timing Chain Cover / Oil Sump
    #53
    Jul 2018
    8 Post(s)
    Yep made sure to use a brand new o ring on the back of the bearing bush (N909 032 01).
    I had the tangs facing towards me as I installed as it looked as if they were going to crush up against the timing chain and oil pump sprockets....hope that doesn’t impact anything.
    All dry as a bone after getting it up to temperature. Fingers crossed.
    Was’nt fun work in this heat!
    Thread repair went well too. I ended up renting the tools to do the job properly.
    Thanks for the help it’s much appreciated.
  4. Re: Oil leak - Timing Chain Cover / Oil Sump
    #54
    1841 Post(s)
    Something important I forgot to mention, if using an original style thin lipped (unsprung) Teflon seal, DO NOT lubricate it, the seal and the bushing must be perfectly dry and clean as must the Diamond washers and their contact faces.
  5. Re: Oil leak - Timing Chain Cover / Oil Sump
    #55
    Jul 2018
    8 Post(s)
    Yep everything was cleaned with brake cleaner beforehand.
  6. Re: Oil leak - Timing Chain Cover / Oil Sump
    #56
    1841 Post(s)
    I am trying to drop a pedal box out to get some wring through and I just keep melting.
  7. Re: Oil leak - Timing Chain Cover / Oil Sump
    #57
    Jul 2018
    8 Post(s)
    Hope you got the above sorted in this heat! Been melting all day.
    car is back in the rod and not leaking thankfully so that’s sorted.
    but it does feel underpowered compared to how it was before.
    thinking I must of messed up the timing slightly or something. but not getting any correlation error codes as one would expect.
    It was sort of spluttering when approaching high speeds around 50-60mph
    might be a misfire? Hopefully a coil pack or spark plug??
    didnt behave like this before so confused at so what I’ve done when sorting out the oil leak?
    need to see if a misfire has been detected or if there is a fueling issue? Check fuel trims?
  8. Re: Oil leak - Timing Chain Cover / Oil Sump
    #58
    1841 Post(s)
    Peg and plate it first, I messed up the timing of a BAG in a Touran many years ago, it just moved a fraction but lost lots of power... very very annoyed I was!
  9. Re: Oil leak - Timing Chain Cover / Oil Sump
    #59
    Jul 2018
    8 Post(s)
    Peg and plate it first?
    What do you mean by that? Is that regarding the timing tools?
    I used a DTI and camshaft tool as per workshop manual.
    should I recheck the valve timing to ensure it’s within +\- 0.01mm at TDC?
  10. Re: Oil leak - Timing Chain Cover / Oil Sump
    #60
    Jul 2018
    8 Post(s)
    So can the timing still be out ever so slightly and not trigger and error / correlation fault code?
    its such a pain if I have to strip it again!!
    i did check the timing multiple times when the timing chain cover was of.
    made sure after torquing and 90 degree turn that timing was spot on.
    guessing it has moved when I did the crank pulley bolt??
  1. Audi A6 2.7 tdi Timing chain or timing belt?
    By AigarsH in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-12-2018, 10:08 AM
  2. Question Camshaft/Timing Chain Cover seals after engine repair
    By _tones in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-07-2017, 07:45 PM
  3. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  4. Question Timing Belt or Timing Chain ??
    By thomascy in forum Golf MK5 - 2004 - 2009
    Last Post: 08-09-2009, 05:22 PM
  5. timing chain data for fitting new chain
    By stephen gal in forum Ibiza - Cordoba
    Last Post: 26-05-2008, 03:17 AM
