Thread: Advice on buying A6 Tdi Sport
  1. Advice on buying A6 Tdi Sport
    Unregistered Guest
    I am hoping for some advice after reading some of the other threads.
    I’m about to buy a 53, A6 (130) Tdi Sport saloon from a trusted source. It has done 60k miles and is due a service which will be done before I get delivery. Would this be a major service and should the timing belt be getting done?
    I have had Audi 80s in the past and moved to a VW Passat which is ok but nothing special. This Audi is £9500 with a years warrantee which seems quite reasonable. Does anyone have any tips?
    Bob
  2. Re: Advice on buying A6 Tdi Sport
    135 Post(s)
    2026 Post(s)
    Cam belt is every 4 years or 60k miles so double yes! Make sure the water pump and tensioners are also replaced.
  3. Re: Advice on buying A6 Tdi Sport
    Jul 2007
    If you're buying a Multitronic, also do a search on this forum for buying advice and what to look out for.
    Definately get the water pump and tensioners replaced also, the 1st is as big a job as replacing the belt and a tensioner failure will have the same effect as a belt snapping.
  4. Re: Advice on buying A6 Tdi Sport
    Jul 2007
    Cheshire, or my A6
    I have a 53 reg A6 1.9 TDI Sport 130bhp. Luv it! It's the one with a 5 speed box. Goes well, easily enough torque, and I am still getting 45mpg, yet I am about to service it. Mine has done 45k. The boot is never ending too, which keeps the other half happy!
    Paul
  5. Re: Advice on buying A6 Tdi Sport
    I have now registered with the forum.
    Thanks for the advice, it is appreciated.
    The supplier of the car will do what is required by the maintenance/service schedule so I will check that the water pump and tensioner(s) are also going to be included also.
    bob
  1. Buying A4 1.8T Quattro Sport 2004 help
    By Fullspizz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-08-2011, 02:42 AM
  2. Hi, just looking for TDI buying advice
    By unitzero in forum New Member Introductions
    Last Post: 28-08-2007, 10:51 PM
  3. S8 Buying advice
    By dan256 in forum A8 - S8 - V8
    Last Post: 23-06-2007, 03:10 PM
  4. thinking of buying a tdi sport
    By dexsan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2007, 12:22 PM
  5. A4 buying advice
    By bonafide in forum Audi A4 - Archive Topics
    Last Post: 20-01-2007, 05:41 AM
