Thread: Golf Mk8 Navigation
Results 1 to 10 of 11
  1. Golf Mk8 Navigation
    Apr 2021
    Having connected Android via blue tooth and downloaded the contacts the navigation system does nor recognise the addresses. Entering post codes does work though but what point in having contacts in system? Also able to add favourites to destinations but can't edit list and remove them!! Fortunately have Waze available to use as car system definitely second rate.
  2. Re: Golf Mk8 Navigation
    Apr 2021
    Uk
    8 Post(s)
    To be honest it feels like the built in nav is there for people who don't have a modern phone. Minimum effort for just a placeholder.
    Not much about it is as remotely functional as the one from the previous mk7 family....
  3. Re: Golf Mk8 Navigation
    Mar 2013
    Cardiff
    I too suspect that a lot of VW folk thought that everybody would just use Android Auto.
    Probably in a pit underneath a steam loco somewhere.
  4. Re: Golf Mk8 Navigation
    Feb 2021
    Stockport
    8 Post(s)
    Quote Originally Posted by Cheezy113 View Post
    At least the over the air updates are a step forward. Updating via SD Card (when they'd got around to even making the update) was a right pain on the Mk 7.5.
  5. Re: Golf Mk8 Navigation
    Apr 2021
    Uk
    8 Post(s)
    In theory you could upgrade the maps on the mk7.5 over an Internet connection (WiFi) but it never worked.
  6. Re: Golf Mk8 Navigation
    Feb 2021
    Stockport
    8 Post(s)
    Wasn't that only if you have had the Pro (or whatever the top tier was called) head unit feature set?
  7. Re: Golf Mk8 Navigation
    Apr 2021
    Uk
    8 Post(s)
    Oh it could be, i had NavPro.
    It didn't work though.
  8. Re: Golf Mk8 Navigation
    Apr 2009
    Surrey
    174 Post(s)
    On my Audi A6 which is essentially the same system at the back end, the issue with OTA updates is that they only update the area you are in at the time. The UK is split into 5 or 6 areas so I for instance only get the SE area update as that is where I am most of the time. If I travel outside the area and am there for enough time for the update server to realise I am there I will then get the upate for that area.
  9. Re: Golf Mk8 Navigation
    Jan 2013
    Northern Ireland
    32 Post(s)
    And just for clarity, when we’re talking about ota map updates, am I right in thinking these seem to happen in the background? That is, without getting the notification that an update is available and needs to be accepted? I have noticed updates to the map database have occurred without me having to accept an update.
    Golf Mk 1.5 eTSI 150PS DSG Style
    Reflex Silver / Storm Grey, Winter Pack, Reversing Camera, Headup Display
  10. Re: Golf Mk8 Navigation
    Apr 2021
    Uk
    8 Post(s)
    Yes they seem to happen with no notification. Which is fine by me.
  1. RNS 510 Navigation Gone Mad
    By LindsayD in forum Tiguan
    Last Post: 07-05-2018, 04:20 PM
  2. Android Auto / Google Maps navigation vs Inbuilt Nav Pro navigation
    By MattB247 in forum Passat - B8 Forum - 2015 -
    Last Post: 25-08-2016, 03:57 PM
  3. Navigation system for golf plus v
    By scipi in forum Golf Plus
    Last Post: 27-08-2009, 01:15 PM
  4. Q5 Navigation
    By derekhob in forum Q5
    Last Post: 22-07-2009, 09:24 PM
  5. Any help with the navigation?
    By silentplayer in forum Phaeton
    Last Post: 11-02-2008, 09:21 PM
