Thread: sharan diesel auto
  1. Angry sharan diesel auto
    Sep 2007
    I have a 04 diesel sharan auto, it is sticking in 2nd gear until about 3000 rpm and then it jumps into either 4th or 5th gear, not sure? my local auto trans. specialist? has changed the valve body. that cured the fault but it came back exactly the same after a couple of days, that was the middle of october. now he is saying that he is not sure if the gearbox is faulty or if it icould be the ECU. the car has done 180,000 miles, any body had this problem before?
  2. Re: sharan diesel auto
    131 Post(s)
    1979 Post(s)
    Those boxes are the source of constant grief and I have seen a few older Sharalmbras scraped due to the cost of a new box. Has the gearbox ECU been read for fault codes?
  3. Re: sharan diesel auto
    Sep 2007
    the ECU has been resad for codes , but there are none showing up.
  4. Re: sharan diesel auto
    Sep 2007
    the ECU has been read for codes, but there are non showing up.
  5. Re: sharan diesel auto
    131 Post(s)
    1979 Post(s)
    Well the valve bodies are a known problem but if it is playing up like this it should leave a code. If the valve body is faulty it will be under guarantee but if it has failed due to dirty ATF the warranty will be void, I think the repairer has a duty to deal with this. Where did the valve body come from? VW parts have a two year warranty supported by the dealer network so if it was a genuine part, the dealer will do the work included in the warranty AS LONG AS the valve body is at fault and has not been damaged by any other factor. If the original repairer is proving reluctant to help you need to go somewhere else for more advice and possibly a repair and then take up the issue in the time honoured way.
  1. Sharan Auto Box Issues.
    By delphius1 in forum Touran - Sharan - Caravelle
    Last Post: 31-01-2011, 06:23 PM
  2. sharan vr6 auto gearbox problem
    By sh4h99 in forum Touran - Sharan - Caravelle
    Last Post: 30-06-2008, 10:04 PM
  3. Sharan Auto Gear Lamps Not Working
    By jamjam12345 in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2007, 07:08 AM
  4. Sharan 2.0 auto box cranking problem
    By planefixer860 in forum Touran - Sharan - Caravelle
    Last Post: 28-03-2007, 09:00 PM
  5. starting prob sharan auto
    By andy e in forum Touran - Sharan - Caravelle
    Last Post: 26-01-2007, 11:09 PM
