Thread: Please help, cars missfires on idel, code G247(P119A)
  1. Post Please help, cars missfires on idel, code G247(P119A)
    Jun 2021
    Sweden, Landskrona
    Hey, my car missfires alot during idel, we've done some logs and i checked the 4th coil since im getting missfire codes from it too, looks alright to me and my tuner. Funny enough car runs good when driving but when idel it missfires badly and can sometimes even be heard from the exhaust (popping), car also throws these codes but the P119A is the first to come up.(P0300 static, P0304 static, P0171 static, P2279 static, P2096 static, P1093 intermitten) Most of these codes go away when clearing but some have come back and went with erasing them , HPFP and LPFP seems good when we've logged the car. Still makes the correct boost and doesn't feel slower really than it has before.
    Car is a Cupra R CLDA
    Thanks for help in advance.
  2. Re: Please help, cars missfires on idel, code G247(P119A)
    1840 Post(s)
    P119A - Fuel Pressure Sensor (G247) : Malfunction
    P0300 - Random/Multiple Cylinder Misfire Detected
    P0304 - Cylinder 4 Misfire Detected
    P0171 - Fuel Trim; Bank 1: System Too Lean
    P2279 - Leak in Air Intake System
    P2096 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1 - Too Lean
    P1093 - Bank 1; Fuel Measuring System 2: Malfunction
    Try removing the oil filler cap with the engine running.
  3. Re: Please help, cars missfires on idel, code G247(P119A)
    Jun 2021
    Sweden, Landskrona
    I did, runs worse and sucking in air through the hole when removed. Tuner said it's normal
  4. Re: Please help, cars missfires on idel, code G247(P119A)
    1840 Post(s)
    Which year and CLDA or CDLA?
  5. Re: Please help, cars missfires on idel, code G247(P119A)
    Jun 2021
    Sweden, Landskrona
    Cdla 2012/2013
  6. Re: Please help, cars missfires on idel, code G247(P119A)
    1840 Post(s)
    Disconnect the breather hose into the inlet manifold and cap the opening to let the cam cover breath to atmosphere so the inlet manifold is sealed, see how it idles like this.
  1. G247/fuel related issues
    By EddieLow23 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-06-2018, 08:21 PM
  2. Missfires and hesitation on A8 2004 4.2 Petrol
    By ivanvag in forum A8 - S8 - V8
    Last Post: 27-02-2015, 08:31 PM
  3. Please Help G247 Fuel Pressure Sensor Help
    By A4 Lad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-12-2014, 11:21 PM
  4. Please Help audi a4 2.0 fsi Missfire in cylinder 4 and multiple missfires fault !
    By Rogerout in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2014, 05:08 PM
  5. no faults stored, engine missfires
    By tomcio14 in forum VCDS - General Questions
    Last Post: 15-12-2008, 07:55 PM
