Thread: Golf 2.0 SE TDI Overheating!
  1. Golf 2.0 SE TDI Overheating!
    Feb 2014
    Birmingham UK
    I have a golf mk6 2.0 se tdi - I believe its the CBDC engine
    The car starts and drives fine but after it gets to 90c and you drive it for abit longer, the temperature starts to rise and keeps going up.
    Its just had a new Water Pump + Timing belt, Thermo start
    Mechanic has told me now that its the head gasket and looking at £900 minimum but I'm not entirely sure it is?
    Any advice on what i could check / try ?
  2. Re: Golf 2.0 SE TDI Overheating!
    1841 Post(s)
    There is a casting number on the back of the head, you need to know what this is
  3. Re: Golf 2.0 SE TDI Overheating!
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Do the coolant hoses get hard when the engine is running ?
    If you disconnect the small pipe going to the top of the coolant reservoir, re-direct it into the top of the reservoir with the engine running.
    There should be a constant flow of coolant while the engine is running.
    This proves the new water pump is working ok.
  1. Mk2 golf overheating
    By buzmuzguz in forum Golf MK2 - 1984 - 1992
    Last Post: 25-04-2011, 06:44 PM
  2. golf gt tdi 150 overheating
    By AAGT150 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-04-2009, 12:32 AM
  3. Question Golf Mk4 V5 overheating
    By ataylor in forum Golf MK4 - 1999 - 2004
    Last Post: 14-08-2008, 01:39 PM
  4. VW Golf MK3 overheating
    By diceyjase in forum Golf MK3 - 1993 - 1999
    Last Post: 30-07-2007, 07:21 PM
  5. Golf MK 3 GTI Overheating
    By chris goodwin in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-07-2007, 04:58 PM
