Thread: P 2002 Help Needed...
  1. P 2002 Help Needed...
    Mar 2020
    Manchester
    Hi everyone,
    The error code keeps popping up, whats your thoughts?
    DPF regeneration? EGR cooler full? O2\Lambda sensor fault? Throttle body?
    Please kindly advise. Error code as follows:
    1 Fault Found: 19226 - Particulate Trap Bank 1 P2002 00 [237] - Efficiency Below Threshold MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Mileage: 100325 km Date: 2021.05.25 Time: 20:28:49 Engine speed: 1332.50 /min Normed load value: 66.3 % Vehicle speed: 36 km/h Coolant temperature: 87 °C Intake air temperature: 54 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 13.040 V Unlearning counter according OBD: 40 Exhaust mass flow of low-pressure EGR: calculated: 3.519 Differential pressure ratio: low-pressure EGR: 27.9 kg/h Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 59.0 hPa Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 56.5 hPa Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 86.60 % Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 40.56 % Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 56.3 hPa Readiness: 1 1 0 0 0
  2. Re: P 2002 Help Needed...
    1840 Post(s)
    Looks like the DPF needs to come off and be cleaned
  3. Re: P 2002 Help Needed...
    Mar 2020
    Manchester
    when i check the dpf it shows around 16g of soot or ash, i dont think thats too much or is it?
  4. Re: P 2002 Help Needed...
    1840 Post(s)
    Ash and soot are two different values, the Ash is OK but what is the soot loading %
  1. diagram needed for vacumm on 2.4 v6 2002
    By scanny1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-05-2012, 05:50 PM
  2. A4 2002 1.8t Se - Wheel Advice needed plz ..
    By trix in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-07-2010, 02:36 PM
  3. Hi Help Needed! 2002 TT
    By sneil2 in forum New Member Introductions
    Last Post: 14-12-2009, 03:26 PM
  4. audi a4 2002 **51*** fob needed
    By mudassarazaz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-03-2008, 09:47 AM
  5. turbo for 2002 gttdi150 needed please help
    By tannerzxr in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-06-2007, 08:43 PM
