Re: Quick rear brake pad question A6 Allroad 2013 –
29-05-2021,05:03 PM
Yes just push them back in. You can use a G clamp or a large water pump pliers depending on what you have, just protect the surface if they are painted. Also check the brake fluid once you have the finished as it will be higher than before so may need some removing
RS6 Performance Ascari Blue, Carbon Ceramics Brakes and lots more.
A6 BiTdi Avant MTM
Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds,High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
